Author Topic: [IC] Hunter 3090- 80% keyboard  (Read 18140 times)
Offline made in China
« on: Fri, 01 January 2021, 00:49:28 »
Hello everybody, we are a arts and crafts factory from China, two years ago I was at a close friends began to contact under the misleading of customization, and open the floodgates, began to try to draw and processing aluminum case, is to play or just a few close friends to share, this time in GH to bring a RTX3090 industrial style of a keyboard, I hope you appreciate all efforts put in this project.
Suite name: Hunter 3090
Highlight the RGB fan at the bottom:
1 In the middle of the fan is a brushless motor,
2 The fan blades are made of 6063 aluminum and are anodized
3. The RGB placed above the fan moves as the fan rotates.
4 The bottom of the fan is a piece of tempered glass.
General specifications:
1 Typing Angle: 7°
2 Plate mounting style:Gasket
3 Material: 6063 aluminum, PC
4 weight: Brass (Transparent electrophoresis)
5 PCB: 1.6mm black gold FR4, support QMK&VIA
6. Installation mode: Welding & hot swaped
Interface: USB Type-C daughterboard
Layout: WKL/WK/ISO/ANSI
case Optional color:
1 anodized black
2 Electrophoresis blue
3 Electrophoresis warm white
4 spraying granite color (refer to the rendering, GB will give the color number)
5 Polycarbonate: white frosted
The kit contains a list of accessories
1 aluminum  or  Polycarbonate case
2 Brass weights
3 PCB, RGB lamp, fan
4 foot pad, screw,silicone gasket, manual
https://discord.gg/uvW4xQq3jM
update log:
2020.12.31 ic published
2021.01.02 updated the logo from RTX to GTX
« Last Edit: Sat, 02 January 2021, 05:32:10 by made in China »
Offline war40ck
  • Sadge
Re: [IC] Hunter 3090- 80% keyboard
« Reply #1 on: Fri, 01 January 2021, 00:51:07 »
love it
Tell me why...
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #2 on: Fri, 01 January 2021, 00:58:17 »
Take all my money
Offline VipermanGT2
« Reply #3 on: Fri, 01 January 2021, 01:00:43 »
NO!
Offline Auxo
  • Formerly CJD_Anthony
« Reply #4 on: Fri, 01 January 2021, 01:01:00 »
Uhh lol
Offline KingXF
    • YouTube
« Reply #5 on: Fri, 01 January 2021, 01:21:38 »
I doubt I'll be able to afford this 3090 either :/
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #6 on: Fri, 01 January 2021, 03:22:49 »
I love the creativity but I genuinely doubt you'll be able to sell this in the US (or where IP laws are strict) with a trademarked name: https://www.nvidia.com/content/dam/en-zz/Solutions/about-us/documents/NVIDIA-Trademark-and-Logo-Usage-Guidelines.pdf
« Reply #7 on: Fri, 01 January 2021, 03:59:47 »
Thank you for reminding. I was also wondering whether we would violate the law if we just used RTX, and we added hunter prefix, but it doesn't matter. If it doesn't work, we might change it to RTS, etc. After all, this is just a DIY project involving dozens of people
  • Formerly 'esclab'
    • esc lab
« Reply #8 on: Fri, 01 January 2021, 04:01:22 »
I suggest reading the trademark doc I posted. Contains all the names that you can't use without licensing.
Offline Diggidy
« Reply #9 on: Fri, 01 January 2021, 05:12:22 »
Can it run Crysis?
« Reply #10 on: Fri, 01 January 2021, 05:24:06 »
Offline jamster
« Reply #11 on: Fri, 01 January 2021, 05:56:53 »
Seems to me it would be best to keep the graphics card reference generic anyway. The 3090 is going to be top of the heap for as long as it takes the 4090 to come out. A keyboard should last more than a decade.
Offline FlitzDeelman
« Reply #12 on: Fri, 01 January 2021, 06:30:29 »
From a quick scan of the first few pages, it seems to me you can use “GTX” and “RTX” but not “Geforce GTX” or “nVidia RTX”. Is that right?
Offline Dunne
    • Dunne
« Reply #13 on: Fri, 01 January 2021, 08:10:17 »
China #1  :D
Big XD
  • Formerly 'esclab'
    • esc lab
« Reply #14 on: Fri, 01 January 2021, 09:59:35 »
If I were OP, I would contact a trademark lawyer
Then again, I wouldn't personally come up with designs like this in the first place. Legal gray areas are no fun and not worth the potential pain. If your intuition tells you it might be too close, then it probably is.
I would suggest just getting rid of all potential offending branding. If you try to use a "similar" looking word like RTS, it just looks like a cheap Taobao clone of what you're using as inspiration.
« Last Edit: Fri, 01 January 2021, 10:46:37 by esclab »
Offline HamKenobi
« Reply #15 on: Fri, 01 January 2021, 13:30:51 »
Username checks out
Offline Sicowa
« Reply #16 on: Fri, 01 January 2021, 14:03:39 »
Interesting design.............
https://www.reddit.com/r/ATBGE/
« Last Edit: Sat, 02 January 2021, 13:11:23 by Sicowa »
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline mcmaxmcmc
« Reply #17 on: Fri, 01 January 2021, 14:06:57 »
So what, you would buy this board because you missed the 3090 so you need something expensive on the desk that looks like a 3090 to cry over?
But yeah, trademark. That's gonna eat your ass.
Offline Rocket
« Reply #18 on: Fri, 01 January 2021, 16:31:54 »
Looks cool, but Nvidia will probably crack down on it. Might be alright if you remove the GTX/RTX branding. Would be cool to see if you can do anything with the fan on the front like make it spin, make it into some kind of fidget spinner or turn it into something useful like a rotary encoder.
« Last Edit: Thu, 11 February 2021, 09:34:30 by Rocket »
Offline Chippy
  • sus chef
« Reply #19 on: Fri, 01 January 2021, 18:49:34 »
this is what it's all about. this is what we come here for. this is the stuff.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Emasterbro
« Reply #20 on: Fri, 01 January 2021, 18:56:57 »
lmao, i would get it if <$100 XD
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #21 on: Fri, 01 January 2021, 19:14:36 »
How about RXT 3009 ? Close enough but technically not the same :)
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
  • Formerly 'esclab'
    • esc lab
« Reply #22 on: Fri, 01 January 2021, 19:34:34 »
80082?
« Reply #23 on: Sat, 02 January 2021, 05:33:23 »
80082?
@esclab thanks again,I have alreay change the RTX to GTX
« Reply #24 on: Sat, 02 January 2021, 06:59:01 »
A custom keyboard with a RGB fan ... you can't be serious ...
Offline Jebus
« Reply #25 on: Sat, 02 January 2021, 07:50:46 »
Yup, here we go. 2021 already pulling out some tricks from its sleeves.
Offline jamster
« Reply #26 on: Sat, 02 January 2021, 08:27:38 »
Hang on... is the fan a real fan, or is it just some kind of embossing?
The "brushless fan" bit in the original text suggests it's actually a functional fan... or am I totally misunderstanding this?
Offline NoteMakoti
  • for sale, baby shoes, never worn
« Reply #27 on: Sat, 02 January 2021, 09:40:19 »
By the time this is manufactured, the Lovelace GPUs will be out and the 3090 will be a thing of the past.
Offline CosminOance
  • 'tis the season to be yourself
    • PixelDrama.club by Cosmin Oance
« Reply #28 on: Sat, 02 January 2021, 10:32:31 »
For anyone who's ever seen the UK Top Gear, they have a saying: "Ambitious, but rubbish".
Offline Engedi_
« Reply #29 on: Sat, 02 January 2021, 11:18:42 »
Maybe call it Vortex. The logo looks like one. Vortex GTS or something...
Offline Vigrith
« Reply #30 on: Sat, 02 January 2021, 12:27:56 »
Offline Xdoc6
« Reply #31 on: Sat, 02 January 2021, 14:13:45 »
You have to be careful about more than just the name btw. The design of the card also likely has IP protection. It’s like the people who design keysets based off a show, clearly they are referencing someone else’s work and trying to profit off it. You need to be careful about that.
  • Formerly 'esclab'
    • esc lab
« Reply #32 on: Sat, 02 January 2021, 16:25:38 »
Thinking harder about this (as hard as one can think about something like this), I genuinely don't think this is it chief.
You're not gonna have any vendor willing to sell this unless there are significant design changes.
Also as a fellow 国人, this is a continued bad look for Chinese designers. And I know there is a lot of great original stuff from China that's never shown here from zFrontier.
This ain't it chief.
« Reply #33 on: Sun, 03 January 2021, 18:31:10 »
We decided to modify the structure and appearance of the case, so as to avoid some improper designs that people thought would take about half a month, and wait for me to come back
