Author Topic: KAT 2u spacebar?  (Read 5495 times)
Offline br4n_d0n
KAT 2u spacebar?
« on: Sat, 02 January 2021, 16:25:12 »
Anyone know where I can pick up a KAT 2u spacebar? I can temporarily get by with using some numpad keycap from some random cheap set I have, but would prefer one that actually goes with the kit I have
Offline Sup
Re: KAT 2u spacebar?
« Reply #1 on: Mon, 04 January 2021, 09:51:40 »
Is there a reason not to use 2.25? 2.25 spacebar and then 1u is possible instead of using 2u 1.25u. Not sure what your layout is though but this is what i imagine.
« Last Edit: Mon, 04 January 2021, 09:58:51 by Sup »
current
Coming soon
Offline br4n_d0n
« Reply #2 on: Mon, 04 January 2021, 11:36:35 »
I have a planck mit like build where I only have room for a 2u spacebar.
Offline Sup
« Reply #3 on: Mon, 04 January 2021, 13:52:21 »
Only from KAT GB's. You have to find a GB with a spacebar set and get the 2U from there or try to get one aftermarket on mechmarket or classifieds.
EDIT: https://kbdfans.com/collections/keycaps/products/kat-alpha-pbt-146-40s-ergo-blank-keycaps-set?variant=34430153916555 You can buy it from here but you have to buy the entire 40s kit.
current
Coming soon
Offline br4n_d0n
« Reply #4 on: Mon, 04 January 2021, 19:49:30 »
Yeah, I may have to browse around for a while as it's not really worth it to purchase a large kit for just 1 keycap
Offline mrvco
« Reply #5 on: Thu, 14 January 2021, 21:09:48 »
Which KAT set are you using?  KAT Blanks includes a 2U space bar and sells on r/mechmarket for less than $100.  You should be able to resell the set minus the 2U space bar easily.
« Last Edit: Thu, 14 January 2021, 21:12:19 by mrvco »
Offline br4n_d0n
« Reply #6 on: Fri, 15 January 2021, 12:32:56 »
I have the KAT Eternal set, but I don't really care at this point as long as it is the right profile for the spacebar being convex and nothing is wrong with it. However, to me the one key is not worth the money and extra hassle of purchasing an entire set at the moment. Now if it was a smaller set for a planck and cheaper then I would look at picking it up, but they only seem to offer a set for normal layouts.
