Author Topic: Where is the firmware for Rama Works M65-A?  (Read 4014 times)
Offline pmdbt
    • KeebsForAll Storefront
« on: Tue, 05 January 2021, 19:11:38 »
Hey guys, I just bought a second hand Rama Works M65-A from mechmarket. I wanted to remap a few keys, so I plugged it in and opened up VIA, but VIA doesn't seem to recognize the board. So, I went on QMK to look for a firmware that I can use for flashing, but all I can see are the M60, M65-B, and M65-Bx.
Does anyone know where the firmware is for M65-A? I feel like I'm missing something super simple and that I'll facepalm later. Any help would be appreciated :)
ID80, Rama M65-A, Black Inks V2
Offline Sup
Re: Where is the firmware for Rama Works M65-A?
« Reply #1 on: Tue, 05 January 2021, 19:29:43 »
I know that the Rama M65-A came with a bootmapper PCB and a QMK PCB. This keyboard hasn't been ported to VIA. So you can't use VIA on this PCB.
You have to program it the old school way by having a QMK environment and compile your hex file and then flash it.
I think this is your PCB?
https://github.com/qmk/qmk_firmware/tree/master/keyboards/jc65
current
Coming soon
Offline pmdbt
« Reply #2 on: Tue, 05 January 2021, 20:08:28 »
Thanks for finding this for me! I used the v32a for the jc65 because I saw that the board had rgb earlier. I compiled the hex file and flashed it using QMK toolbox. Now the board is not even being recognized when I plug it in and I have no idea how to enter flashing mode again on it :(
Offline Sup
« Reply #3 on: Tue, 05 January 2021, 20:31:45 »
- Jc65/v32u4 has a reset button on the back.
- ps2avrgb does not
You can try to hold left CTRL and plug it in see if that puts it back into bootloader mode.
current
Coming soon
Offline pmdbt
« Reply #4 on: Tue, 05 January 2021, 21:02:58 »
- ps2avrgb does not
Thank you! I've fixed the issue thanks to your help and I'm typing this on the M65-A as we speak :)
It turns out that even though it has RGB, the PCB was still the v32u4 one and not the ps2avrgb one. So, I unscrewed the bottom and found the reset button on the back of the pcb and was able to put it back into bootloader mode. I flashed a new firmware using the jc65_v32u4 version on QMK and now it's all good.
I hope this helps someone in the future if they run into the same issue.
