Author Topic: Don't use your oven as a dryer!!!  (Read 15173 times)
Offline 8_INCH_FLOPPY
« on: Sun, 08 August 2010, 20:25:08 »
I bought a beautiful, white Cherry keyboard with a working navigation pad today.  I then proceeded to disassemble it and sped 1.5 hours removing, washing and drying each individual key.  No, I'm not obsessive-compulsive. I just like my new keyboard to be clean... The keys were so pretty.. I was so impatient that I put them in the oven to dry for *just a second* and then got distracted.  5 minutes later I was horrified to smell my melting keys.  I now have a spotlessly clean white keyboard with Cherry black switches, a working touch-pad, and*Sob* a melted mass of white plastic.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline ch_123
« Reply #1 on: Sun, 08 August 2010, 20:43:25 »
I am really curious - why didn't you just use a towel?
« Reply #2 on: Sun, 08 August 2010, 20:45:03 »
The holes in Cherry key-caps are impossible to dry out with a towel.
HAPPY HUNTING
Offline TexasFlood
« Reply #3 on: Sun, 08 August 2010, 20:47:53 »
Quote from: 8_INCH_FLOPPY;210517
Oh man!  That's a shame.  I know how it can happen though.  I burned up two oven top tea kettles that way so finally bought a Hamilton-Beach that has an integrated automagic heating element that shuts off by itself.  And once I tried to blow some crap out of a laptop keyboard with a hair dryer, got too close and slightly melted the front of some function keys.  Some lessons, such as patience and caution, apparently need to be relearned periodically, :sad:
« Last Edit: Sun, 08 August 2010, 20:50:15 by TexasFlood »
Offline ch_123
« Reply #4 on: Sun, 08 August 2010, 20:49:45 »
Sorry, I thought you were talking about the case. Well, that sucks...
Offline Brodie337
« Reply #5 on: Sun, 08 August 2010, 21:06:15 »
My preferred approach is to do it with a hair dryer,  or just leave them in the sun a while.
Offline patrickgeekhack
« Reply #6 on: Sun, 08 August 2010, 21:43:43 »
Isn't there a way to get keycaps? Can't you buy them, or buy a broken Cherry keyboard?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline ThirdLap
« Reply #7 on: Sun, 08 August 2010, 22:09:06 »
Next time:
- Preheat oven to ~180°F
- Turn oven off
- Place item to be dried on a cookie sheet
- Place in oven
Never had a problem with this method.
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #8 on: Mon, 09 August 2010, 00:46:48 »
:evil: This is absolutely a move to encourage spending $175 on your own custom colored double shots from signature plastics.  Getting a cheap board, for replacement caps just isn't the same.
:angel: At least in times like these there are replacement key cap options, even if they aren't as nice as just ordering up a set and receiving them within a week.  I definitely prefer things that can be repaired, to those that need recycling.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline vils
« Reply #9 on: Mon, 09 August 2010, 02:48:45 »
And don´t use your fridge as an oven:
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
« Reply #10 on: Mon, 09 August 2010, 02:59:49 »
I have done the same. Not with a keyboard, but with another item made of plastic. It can happen quite fast.
« Last Edit: Mon, 09 August 2010, 03:29:17 by Findecanor »
Offline British
« Reply #11 on: Mon, 09 August 2010, 04:39:32 »
Hmmm, I cleaned 3 keyboards worth of keys this week-end.
To have they dry, I put them on a towel, bottoms up, near an open-window.
You just have to not be in a hurry and be careful if the sun is hitting the keys for a long period.
Offline whininggit
« Reply #12 on: Mon, 09 August 2010, 05:19:09 »
Sorry you damaged your keys, but it reminds me of this:
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline TexasFlood
« Reply #13 on: Mon, 09 August 2010, 08:49:52 »
Quote from: whininggit;210558
Is that the one where Kramer ends up with Cubans sleeping in his dresser drawers?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #14 on: Mon, 09 August 2010, 10:18:52 »
PBT already has a higher melting point than, say, ABS, so that oven must've been rather hot indeed. The 50°C setting would have been a good idea...
Offline instantkamera
« Reply #15 on: Mon, 09 August 2010, 10:40:06 »
Quote from: TexasFlood;210587
That was Japanese businessmen...
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
« Reply #16 on: Mon, 09 August 2010, 11:03:58 »
And the "Cubans" were really Dominicans :)
Offline keyboardlover
« Reply #17 on: Mon, 09 August 2010, 11:09:17 »
From what I've heard, baking an electronic device in the oven can be a good way to fix soldering issues inside (as the solder will re-set). Haven't tried it myself though and I'm sure that mileage varies...
Offline TexasFlood
« Reply #18 on: Mon, 09 August 2010, 11:20:07 »
Quote from: instantkamera;210620
Quote from: instantkamera;210625
Oh man, I know just enough Seinfeld to be dangerous, should have consulted my son who has it all committed to memory before posting, :biggrin:
Offline Voixdelion
« Reply #19 on: Mon, 09 August 2010, 11:34:20 »
This thread needs to be retitled: "Why boys need parents..." :)
More examples:
boys001
boys002
boys003
boys004
boys005
boys006
boys007
« Last Edit: Mon, 09 August 2010, 12:05:07 by Voixdelion »
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline itlnstln
« Reply #20 on: Mon, 09 August 2010, 11:48:25 »
Quote from: Voixdelion;210634
There was something painfully obvious about the thread title...
Offline Voixdelion
« Reply #21 on: Mon, 09 August 2010, 12:04:20 »
Quote from: itlnstln;210642
VERY painful...
Offline Voixdelion
« Reply #22 on: Mon, 09 August 2010, 12:06:32 »
Quote from: ripster;210646
Tasteless Literary Joke time
I don't get it.
Offline Voixdelion
« Reply #23 on: Mon, 09 August 2010, 12:32:15 »
Quote from: ripster;210664
Hey, that's me as a child!
Well, that explains quite a bit!  :tongue:
Offline vils
« Reply #24 on: Mon, 09 August 2010, 12:51:02 »
Quote from: Voixdelion;210661
I don't get it.
Just recall how she died...
« Reply #25 on: Mon, 09 August 2010, 12:51:16 »
I've been drying things in my oven for years.  This is the first time I've destroyed something, and the cause of that was me getting distracted, hitting the wrong button, and leaving the room.  Based on my experience, the risk that something will go wrong outweighs the faster drying times of drying things in the oven.  As you can see from the comments, there may still be a few people who think that using the oven as a dryer is a good idea.
Anyway, do any of you have an extra set of keys?  I can't afford to spend an exorbitant amount of money on new ones, and I don't care what color they are.
HAPPY HUNTING
Offline itlnstln
« Reply #26 on: Mon, 09 August 2010, 12:55:16 »
No biggie; I was just being an ass. Hell, there's people that wash certain parts of their keyboards in the dish washer, and some of them had similar results.
« Reply #27 on: Mon, 09 August 2010, 13:07:09 »
I've always considered the dishwasher a horrible idea, for a number of reasons.  At least with the oven, you have control over the temperature... Unless you make a mistake that is.
HAPPY HUNTING
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #28 on: Tue, 10 August 2010, 05:18:15 »
Quote from: ripster;210628
When we got bored in the dorm....
Reminds me of this awesome microwave video...
hl=en_US&fs=1">
hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385">[/youtube]
A Ghost From The Past
Offline Ekaros
« Reply #29 on: Tue, 10 August 2010, 08:30:10 »
Hmm, so what is realy melting point of plastic? So if I need to dry my comp parts in future just throw it at bit under 100C and use the air-circulation mode?
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Ekaros
« Reply #30 on: Tue, 10 August 2010, 10:39:59 »
Quote from: ripster;210897
Depends.
Definitely keep it under 100 deg celcius and 2 minutes though.
Hmm, ok that does look kinda "over-cooked"... Hmm, now I know it would be bad idea, have to think about something which keep it well under 100...
Next to wonder how much it would cost to make keys which could stand almost anything, maybe metal onces...
[SIGPIC][/SIGPIC]
« Reply #31 on: Tue, 10 August 2010, 15:50:40 »
So, even with all of the nutcases on this forum who have 20 keyboards and are willing to spend +$150 on a custom set of keys, none of you have an extra set of Cherry keys sitting around?  Your just going to let a poor, innocent, clean Cherry keyboard sit around unused and unfulfilled.:frown:
HAPPY HUNTING
Offline EverythingIBM
« Reply #32 on: Tue, 10 August 2010, 17:10:49 »
Quote from: 8_INCH_FLOPPY;210699
Dishwasher is OK for cheap crappy rubber domes (against the common opinion that good qualtiy keyboards can be put in it). Old IBM Model F keyboards would rust.
Quote from: 8_INCH_FLOPPY;211081
You could always make your own keys out of plasticine?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #33 on: Tue, 10 August 2010, 17:17:03 »
You can salvage some Cherry-compatible keys off some rubber domes. I know that most Gateway2000 keyboards use Cherry-compatible keys.
« Reply #34 on: Tue, 10 August 2010, 20:27:25 »
I noticed my programmable Gateway2000 Anykey board has the same keys.  I'd never be willing to take them of of that though.  It's such a fantastic keyboard.
HAPPY HUNTING
« Reply #35 on: Tue, 10 August 2010, 20:37:02 »
Quote from: 8_INCH_FLOPPY;211188
You could always go buy some cheap cherry keys or pull them off a cherry board that isn't a rubber dome. They'd probably be beige though -- but that's okay, beige is cool.
Offline Ekaros
« Reply #36 on: Tue, 10 August 2010, 22:03:23 »
Quote from: microsoft windows;211135
Hmm, intreting... Anyone have any list of which boards have combatible keys for MX switches?
[SIGPIC][/SIGPIC]
Offline British
« Reply #37 on: Wed, 11 August 2010, 01:54:43 »
G81.
You can do some research, though I am not sure which layout you finnish people use.
Offline Voixdelion
« Reply #38 on: Sat, 14 August 2010, 04:26:26 »
Quote from: Ekaros;211220
Hmm, intreting... Anyone have any list of which boards have compatible keys for MX switches?
Well, no list per se, but after peeking at the latest arrival, I do know that the keycaps on the NIB chicony 5191 (white cherry clones)  I got for about $22 shipped from here do fit (almost better than the originals actually - tighter, anyway) on the Adesso  (real cherry blues).  Is that helpful?
Offline Ekaros
« Reply #39 on: Sat, 14 August 2010, 21:18:05 »
Quote from: Voixdelion;212495
Originaly thinking of other Cherry non-g80 models as they do make POS-stuff with finnish/swedish layout, but not mechanical onces... Keycaps like Steerseries 6gv2 pan-nordic model would be good too, acctualy I would buy that board, but I want some tactility...
*Goes to curse them for only making us/uk/de mx-caps*
[SIGPIC][/SIGPIC]
