Author Topic: Oddball - a split keyboard with trackball  (Read 14763 times)
Offline grubnatius
« on: Thu, 21 January 2021, 20:17:52 »
The Oddball Keyboard
260204-0
Version 2
260206-1
Version 1
I shared this around a few places, but thought it'd be good to document on geekhack. I've finished my second build/version of my design, following up from one I made earlier in 2020, which I dubbed the Oddball.
Features
  • trackball (supports both PMW3360 or ADNS9800 sensors)
  • split design
  • columnar stagger
  • 5° typing angle
  • 8.5° tenting angle
  • separate plane for thumb clusters
  • USB-C to host (PC)
  • TRRS to link halves
Links
Offline jamster
Re: Oddball - a split keyboard with trackball
« Reply #1 on: Thu, 21 January 2021, 20:59:46 »
That's brilliant- great colour scheme and overall theme too!
I am surprised that you get by with so few thumb keys. Guessing that one of the left thumbs is a layer activation key, but is there another somewhere else?
« Last Edit: Thu, 21 January 2021, 21:01:28 by jamster »
Offline grubnatius
« Reply #2 on: Thu, 21 January 2021, 21:54:09 »
Yep, you guessed it, layer 1 on the left thumb, layer 2 on the right. I've changed it slightly since this pic, but the basic layout is:
Offline jamster
« Reply #3 on: Fri, 22 January 2021, 05:21:22 »
Interesting to see that your Fn and number(pad) keys do not overlap at all.
« Reply #4 on: Fri, 22 January 2021, 06:34:28 »
Impressive that you can get by with to few keys, your mapping looks crazy to me (alt on home row over backspace, space outside ; and gaps between home end pg up and down for a start) but you have your reasons no doubt.
Looks great too :thumb:
Offline jamster
« Reply #5 on: Fri, 22 January 2021, 08:01:24 »
Huh, Enter is on a layer... I've got two thumb-actuated Enter keys and use both.
Offline ergonaut
« Reply #6 on: Fri, 22 January 2021, 08:07:56 »
It looks absolutely glorious, well done!
For my own taste, there's way too few thumb keys, but as long as it works for you...
Offline grubnatius
« Reply #7 on: Wed, 27 January 2021, 07:48:41 »
Yep, seems a common opinion people bring up. The code is pretty easy to tweak, so I'm thinking of generating some files with 3 thumb keys on the left and 2 on the right, and adding the files to the repo.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #8 on: Wed, 27 January 2021, 11:33:06 »
Very nice and unique design. Well executed.
Offline darryldh
    • loprokb.ca
« Reply #9 on: Tue, 16 March 2021, 09:14:36 »
love this board so much!
