Author Topic: DSA 2x2 Block Key  (Read 3832 times)
Offline mustardgreens
DSA 2x2 Block Key
« on: Fri, 22 January 2021, 14:48:59 »
SP has a DSA 2x2 block key: https://pimpmykeyboard.com/dsa-2x2-block-key/
It is obviously intended for industry use, but I am curious if anyone has used it on an enthusiast keyboard or macropad?
Any ideas on the best way to implement it? Thinking of throwing on my upcoming CU7...
« Last Edit: Fri, 22 January 2021, 14:51:47 by mustardgreens »
Offline Argan12345
Re: DSA 2x2 Block Key
« Reply #1 on: Sat, 23 January 2021, 00:45:49 »
I just got some. The best use I could think of is putting it up above the numpad on a classic g80-1800 layout keyboard as a delete key, since I don't use half of those nav keys anyway.
« Reply #2 on: Sat, 23 January 2021, 01:02:33 »
Not sure what you mean by implement - it fits on four switches so self stabilises, you might want lighter springs in them depending on use.  In firmware you just leave 3 of the keys unassigned so it doesn't appear to chatter.
Offline Darthbaggins
  • PC Cannibal
« Reply #3 on: Mon, 25 January 2021, 09:04:07 »
I know I have some dual post 2u-2.25u caps that I got of an old Gas station POS terminal, part of me wants to find a way to use them in a build but then I would have to link two switches to activate that one key.  Guessing that 2x2 is the same thing as well, more than likely it is originally meant for a POS terminal or something like it.
