Author Topic: Aftermarket Cooler Master NovaTouch Cases  (Read 3329 times)
Offline Chasseur
  • I'm here for the nuts
« on: Sat, 23 January 2021, 11:13:56 »
Hi all, while digging through my cupboard (yay moving) I came across a keyboard I haven't used in a while: a Cooler Master NovaTouch TKL. I was hoping to move the board to an aluminum case, but I missed the
Norbauer Norbatouch group buy by a few years. I've already reached out about a possible single-purchase item from Norbauer. In the meantime, has anyone had any experience with a NovaTouch in one of these cases?
  • eBay TKL: No visibility on the internals, so I can't tell if the NovaTouch's plate would mount in it.
  • TKL Tex: This looks like it might work with some mild micro-USB rerouting.
Does anyone have experience mounting a NovaTouch in any of those cases? If someone has those cases and can share dimensions of the internals or compatibility with something like a Cooler Master Masterkeys S that would also be very helpful. Suggestions are also welcome.
Offline Sup
Re: Aftermarket Cooler Master NovaTouch Cases
« Reply #1 on: Sat, 23 January 2021, 14:56:29 »
Those keyboards you mention are meant for the Filco and Coolermaster, but a novatouch is way different then those MX boards. Even if it fits the daughter board will not work with it. You can also get a Norbatouch case on mechmarket probably, but you will pay a premium.
current
Coming soon
Offline Chasseur
« Reply #2 on: Tue, 26 January 2021, 09:19:54 »
Thanks for the response, I'll take a look at mechmarket. Norbauer is also open to producing a single custom item.
Offline pinkpurpleteal
« Reply #3 on: Sun, 31 January 2021, 02:32:02 »
I have made some fc cases. I am working on a novatouch case, but its super initial. just have some initial models drafted out.
Offline Chasseur
« Reply #4 on: Mon, 08 February 2021, 18:19:27 »
That's exciting to hear, what is the best way of keeping informed of developments?
