Author Topic: Compaq Plus to usb?  (Read 3102 times)
Offline ivanthetolerable
Compaq Plus to usb?
« on: Sat, 23 January 2021, 16:24:36 »
Does anyone know how I would convert it to usb? I think it's standard XT like a Model F so I was hoping I can use a teensy. Any advice?
Offline nevin
Re: Compaq Plus to usb?
« Reply #1 on: Sat, 23 January 2021, 16:45:49 »
unfortunately i believe it's foam & foil.
you can easily tell by feel or removing a keycap
https://deskthority.net/wiki/Foam_and_foil
https://deskthority.net/wiki/Buckling_spring
« Reply #2 on: Sat, 23 January 2021, 16:51:01 »
Yes, I know it is. I'm building a sleeper inside the old case and wanted to make the keyboard usable. I was hoping to see if there's any guides to convert using a teensy
Offline nevin
« Reply #3 on: Sat, 23 January 2021, 17:08:42 »
i'd be more worried about reliability of the foam & foil, unless you are replacing them as well.
if it does use the XT protocol, you could use either hasu's or soarer's converters.
hasu     https://geekhack.org/index.php?topic=72052.0
soarer   https://geekhack.org/index.php?topic=17458.0
check this thread, looks like they figured out the pinout of the connector
Code: [Select]
Female connector that plugs into the keyboard, fat side up:
 [123]
 |456|
 1: GND
 2: VCC (+12V)
 3: GND
 4: RST?
 5: DATA
 6: CLK
and this came up in the search and he repairs the foam & foil pads with replacements
Offline Tactile
« Reply #4 on: Sun, 24 January 2021, 10:00:36 »
Soarer's converter running on a Teensy will do what you want. You can build it into the board or just throw together something like this:
260477-0
Step one will be to identify the wires at the plug. There should be Power, ground, and two data wires. If you can identify power & ground, that's enough to hook up to a Soarer's converter. The data wires can be switched back & forth 'till the board works. There's no risk if you get them backwards.
REΛLFORCE
« Reply #5 on: Sun, 24 January 2021, 10:51:45 »
They should run on any board with an ATmega32u4, such as a Pro Micro clone -- which would be cheaper than the Teensy. Just be sure that the same port pins are available as the ones that the converter firmware uses. With Hasu's there are a few options for which pins to use. I think Hasu's would also work on a few other AVR microcontrollers.
