Author Topic: [IC] Lotus - A 40% split columnar stagger keyboard with satellites - Update 5/8  (Read 9702 times)
Offline misononyan
The Lotus
IC FORM:
https://forms.gle/WVc4pgoe2HDnWizz9
Misonoworks Server:
https://discord.gg/W75Ms5HbjZ
Update 5/8
Long time no update, but this project is still active. My vendor recently just built his protos, and we are almost ready to go into a GB. The vendor who will be hosting this is Vala Supply.
As you can see, the images got a fair facelift. There will be two skeleton case offerings, gloss white and matte black plates.
We will be anticipating a max order quantity of 50. Hopefully that's not too optimistic, but that's what I have gathered based on IC metrics.
The Lotus is a 14-column split keyboard with what I have coined as "satellites." These satellites, being the standout feature of the board, connect via a second TRRS jack and into an I2C compatible board to power a key cluster, another rotary encoder, or an OLED. Alternatively, it should be possible to power a mini i2c trackball, but this is as of yet untested.
Features:
- 14 columns with a columnar stagger to match that of the Kyria
- MX and Choc Compatibility
(Choc switches w/ MBK keycaps on the left, MX switches w/ SA blanks on the right)
- Supports up to 2 rotary encoders, 4 when using satellites
- Ortho and ergo kit compatibility
(KAM Little Pilot ortho + OLED satellite)
- Multipurpose hotswap satellites able to handle a multitude of different modules
Layout
Typing test:
Current vendor(s): Vala Supply
Current price estimate:
Full kit (comes with PM, all parts needed for assembly + extras) - $90-100
Skeleton kit (comes with plates, PCB only) - $40-45
IC FORM:
« Last Edit: Sat, 08 May 2021, 23:07:45 by misononyan »
Re: [IC] Lotus - A 40% split columnar stagger keyboard with satellites
« Reply #1 on: Sat, 23 January 2021, 21:18:22 »
Lo dis nuts
Offline powwu
    • Discord
« Reply #2 on: Sat, 23 January 2021, 22:32:10 »
preeetty
me likey even if I can't use
Offline misononyan
« Reply #3 on: Sat, 23 January 2021, 22:53:40 »
preeetty
you should give it a shot, was my first colstagger ortho and didn't give me too much trouble... but it did give me a little bit lol
Offline Kyakotaa
« Reply #4 on: Sat, 23 January 2021, 23:15:56 »
I really like the satellite concept. Perhaps some sort of 3d printed frames to hold them/angle them up could be doable? Seems like it would add to the modularity of it.
 I also recommend amending the IC to include an optional email field for updates.
Offline Pandamom98
« Reply #5 on: Sat, 23 January 2021, 23:39:15 »
preeetty
This is probably going to be my first ortho board as well
Edit: spelling is hard when you're tired lol
« Last Edit: Sat, 23 January 2021, 23:41:00 by Pandamom98 »
Offline misononyan
« Reply #6 on: Sun, 24 January 2021, 00:06:18 »
I've been working on 3d printed satellite blocks which will be available on a github repo at GB. The board's files will be open source :)
Offline Pandamom98
« Reply #7 on: Sun, 24 January 2021, 06:00:14 »
Stop making me want to get a 3d printer now *annoyed panda noises* /s (lol)
In all seriousness though thats awesome that they'd be open source
« Reply #8 on: Sun, 24 January 2021, 23:29:10 »
preeetty
ACHKSHUALLY it's not ortho sir. This would be classified as a column-staggered layout /nerdrant
Offline Pandamom98
« Reply #9 on: Mon, 25 January 2021, 04:34:52 »
preeetty
In that case it'll be my first one of those lol
Offline Kyakotaa
« Reply #10 on: Mon, 25 January 2021, 07:01:36 »
Absolute king.
Offline misononyan
Offline misononyan
Long overdue update bump
