Author Topic: Steelseries Apex Keycaps  (Read 3899 times)
Offline Kylian
« on: Mon, 25 January 2021, 12:38:48 »
Hi! I have a Steelseries Apex keyboard, 64150, and some of my keys have lost the drawing of the letter, they are only transparent, I have tried to contact steelseries but they do not send replacement for this keyboard, is there any place where I can buy keycaps?
Thx in advance!
This is the keyboard, https://steelseries.com/gaming-keyboards/apex-gaming-keyboard
« Last Edit: Mon, 25 January 2021, 12:42:46 by Kylian »
Offline mustardgreens
Re: Steelseries Apex Keycaps
« Reply #1 on: Fri, 29 January 2021, 10:00:30 »
Never seen this before:
Looks to be some proprietary rubber dome-slider mechanism. The board is no longer supported by Steelseries. You could be out of luck.
Offline Kylian
« Reply #2 on: Fri, 29 January 2021, 14:34:41 »
Thx you so much for your answer!
I have been looking at many websites but I have not found anything, it is a shame because the keyboard is great for me, I have thought to switch to a mechanical one but it barely makes noise and I do not know, well I will keep looking, if someone finds something I would appreciate it much.
I have even thought about painting the key, but I have not found the typeface that steelseries uses for this keyboard.
I said if someone comes up with something, I need help, I'm blocked.
Cheers
