Author Topic: Keychron k2 starts spamming a row of letters after soldering  (Read 4686 times)
Offline foonone
« on: Sun, 31 January 2021, 11:15:49 »
Hi @ all
did i just killed my keychron pcb?
After installing new switches i had a spamming of :" agh'ashj\sj;LKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLKLK "
is there a way to fix it?
Best regards from Germany
« Last Edit: Sun, 31 January 2021, 11:18:11 by foonone »
Re: Keychron k2 starts spamming a row of letters after soldering
« Reply #1 on: Sun, 31 January 2021, 11:27:05 »
I see missing pads on the two switches just off the bottom left corner of the big white printed box, doesn't look like they should be linking back to the controller but if they are that could be the problem so try linking those two to the lower pins of the switch either side to complete the row circuit but if they need to connect to something on the other side you'll not have much luck (unless you can see what's going on on the other side through the plate)
Offline yui
« Reply #2 on: Mon, 01 February 2021, 06:22:17 »
to me looking at it quickly it looks like a short, as usual i do not know that flux you used but as some of them are conductive i would recommend cleaning it, and also check for solder bridges around the middle row, and especially near K and L
Offline foonone
« Reply #3 on: Tue, 09 February 2021, 06:50:47 »
first of all sorry for my late answer!
and thank you for your quick replies!
finally i had some time to desolder all switches. found at least one damaged / broken pad?
i guess its rip for the keychron then.
« Reply #4 on: Tue, 09 February 2021, 07:12:18 »
If you've desoldered all the switches please take some nice photos of both sides (if you can, it's a black PCB so not easy)
It is fixable with just a couple of wires (if that is the only damaged pad, a few more if there are more) but working out where they need to go is tricky.
Offline yui
« Reply #5 on: Tue, 09 February 2021, 07:22:46 »
it never is the end, unless you want it to be, and i am guessing you do not :)
Offline chromov113
« Reply #6 on: Tue, 09 February 2021, 08:17:19 »
If I was you, I would continue troubleshooting, just of curiosity. Did you try connecting a PCB without switches to a PC?
Best regards
Andrey Studentsov
