Author Topic: [GB] NEO Palette G67 Carbon - Full Carbon gakset 65% kit. GB Ended  (Read 10236 times)
Offline Patrickwu
« on: Tue, 02 February 2021, 04:48:28 »
Original IC Post Link
Place your orders here
NEO Palette G67 Carbon groupbuy starting on Feb 5th, at 11:00am of Hongkong Time (UTC+8) (https://www.timeanddate.com/worldclock/converter.html), ending on Feb 21st.
GB has ended.
This will be an unlimited gropubuy, there will be no MinOQ or MaxOQ.
Lead time will be 60-90 days, and will not be affected by Chinese New Year holidays.
Join NEO Keys Discord for more information and progress updates
Palette Carbon G67 kit will include:
1.   Full Torayca 3k twill weave carbon fiber case (4 layers of case body, 2 layers of feet), extra acrylic bottom layer(optional if you prefer RGB lighting)
2.   1.5mm carbon fiber plate
3.   Hotswap or soldered PCB
4.   Poron Gasket
5.   Plate/PCB foam and PCB/case foam
6.   Silicone Feet
7.   M2x8 flat head screws *32 (4 extra)
8.   M2x10 brass posts *16 (4 extra)
9.   M2x4 round head screws *6 (2 extra)
10.   M2x5 brass posts *6 (2 extra)
11.   M2x3 low profile flat head screws *16 (4 extra)
12.   M2x3.5 custom aluminum posts *8 (2 extra)
13.   USB-C Cable
14.   Microfabric cloth
Extra PCB/Plate kit available for sale as well
The kit includes:
1.   PCB
2.   Plate
3.   PCB/Plate foam
4.   Gaskets
5.   M2x3 low profile flat head screws *16 (4 extra)
6.   M2x3.5 custom aluminum posts *8 (2 extra)
PCB Features:
NEO67 Hotswap PCB
-QMK programmable
-North facing switch mount
-Per-switch SMD RGB light
-RGB blacklight
-Center mounted USB-C port
NEO67 Soldered PCB
-QMK programmable
-South facing switch mount
-ISO, Split Backspace, 7U spacebar compatible
-RGB blacklight LED x18! Ultra bright!
MechMerlin's live stream build of NEO Palette G67 Carbon:
https://www.twitch.tv/videos/913001537
There is typing and sound test if you're curious how a gakset full carbon fiber board sounds and feels.
« Last Edit: Mon, 22 February 2021, 01:04:23 by Patrickwu »
NEO Element G67 Kit Groupbuy
Offline Nuclear Nachos
  • Anima and Animus
any chance you could do a sound test?
Offline Patrickwu
there will be a build stream with sound test sometime next week.
I'll post it here.
Offline hello21
I've watched the build stream. I liked the sound. I am convinced.
Here's the link if anyone's interested:
Offline Patrickwu
Offline iscng330
Hi, I am a beginner, may I know is it compatible with cherry silent mx switch? thank you
Offline Patrickwu
yes it is compatible.
Offline iscng330
Thank you ;D
BTW, will you have a 87key version?
Offline Patrickwu
Thank you ;D
That will be the next next project.
Offline iscng330
haha... thanks
Offline Briaireous
Excited for my first GB purchase. Grabbing solder and hotswap options with clear frosted acrylic bottom. After seeing MechMerlins build stream I couldn't resist!
Offline thatkidarkib
How come the hotswap PCB is north-facing while the solder PCB is south-facing?
Offline thelateclacker
So the OP only mentioned QMK, but in MechMerlin's build stream it shows him using VIA to change lighting modes and such.  Does that mean the PCB supports both QMK/VIA?
Offline Patrickwu
That is correct.
Offline Patrickwu
they were developed separately time wise. There was a change of mind between the gap.
Offline Shehuizhuyi-hao
I just have interest in it, do you guys base in China? and do you have qq group account?
Offline Patrickwu
sorry i really dont have time to manage a QQ group. For more info please join my Discord server.
