Author Topic: [IC]Therian40  (Read 9865 times)
Offline Touch Types
  • Smol keebs are best.
    • Touch Types
[IC]Therian40
« on: Sun, 07 February 2021, 18:42:38 »
Therian40
If you're at a loss when it comes to finding a functional, available and great looking 40%, then you're in the right place.
The therian 40 is arguably the most versatile case in the 40's market with the ability to use both Staggered PCBs AND Orhtolinear by simply swapping the plate.
This feature on its own would be pretty cool, however, who wants to unscrew their case to swap the PCB?!
Our solution to that problem? Magnets.
By making use of magnets, we are able to have the top and bottom case securely fastened while also allowing the user to easily and quickly swap out their PCBs to fit their needs.
Our design essentially takes 'hot-swap' to the next level...
As well as using magnets in order to hold the case together, we have also decided on Sorbothane as the gasket material for its incredible sound and vibration dampening properties to hopefully give a great sounding 'Clack' profile.
Renders
*Unfortunately I can't get any images to load directly into GH so you'll have to use the Imgur gallery linked below, sorry for the inconvenience. *
Imgur Gallery: https://imgur.com/a/IHJjxDx
IC Form
The following link will lead you to a Google Form with a  variety of questions that will allow us to ensure that the keyboard is best tailored to you, the end-user.
It shouldn't take longer than 10 minutes to complete and it would be greatly appreciated if you provided as much detail as possible so that we have more to work off of.
Link: https://forms.gle/7g5f98LaGotiEbmY8
Features
- Magnet mount connection [MMC]
- Sorbothane gaskets [SG]
- 5° typing angle
- Multiple layout support
- Universal USB port access
- 100% screwless assembly
- Quick-switch PCB swapping
Supported PCBs
This list is not comprehensive as any 12u x 4u PCB should work so long as they don't have weird spacing. The PCBs listed below are just those that have been physically tested.
We are still exploring the Ortholinear PCB options as we may need a 3rd plate in order to support the spacing for the Planck PCB.
- JD40
- BM40
- Planck
PCBs on order(To be tested)
- Niu Mini
- AMJ40
- Anything else that you suggest.
Behind the name
The name is the first thing you see when having new designs marketed towards you so it's vital that we pull you in off the bat.
"Therion" in Greek translates to "wild animal or beast," however when combined with the word "Anthropos" which means "human", you get "Theriantropy".
In essence, Theriantropy is the Ancient Greeks shapeshifting mythology.
Shortening that, we get "Therian" which doesn't technically mean anything but with some appreciation of greek mythology and an understanding of the design, you should be able to see the connection.
I also felt that 'Therian' sounded as though it could be used as a name for a spaceship which funnily enough, fit very nicely as we had considered space-age design elements when exploring this design.
Materials
The final materials are still to be decided and will take cost as well as demand/interest into consideration.
For the renders the top is Aluminium and the base is frosted Polycarbonate.
These 2 materials are the current working materials for quotes etc but dependant on demand these can be altered to get more accurate quotes and end prices for you.
No matter what the case materials, there will also be an engraved Brass or Steel weight in the base.
The design for this engraving is still in the works but it will be posted here as well as on all other IC posts to get your opinion before the "Ok".
As for the plate materials, these will come from the results of the IC form and will then be taken forward to manufacturers for quotes.
Contact
If you have any further questions, please don't be afraid to ask, you're critique will make this board. You can reach me at any or all of the following outlets:
- Twitter: TouchTypes
- Instagram: touch.types
- Email: touchtypescontact@gmail.com
- Discord: Touch Types#5593
If you would like a more organised display of the progress you can also check out my website which will be updated as the process goes on.
Website: https://touchtype.online/
Finally, for the most active source of information please our Discord server.
Discord: https://discord.gg/PdHMEHCb6f
« Last Edit: Mon, 22 February 2021, 15:41:49 by Touch Types »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC]Therian40
« Reply #1 on: Sun, 07 February 2021, 18:47:11 »
ne proto avail
Offline JoltFX
Re: [IC]Therian40
« Reply #2 on: Sun, 07 February 2021, 18:47:29 »
Color me interested
Offline Touch Types
    • Touch Types
Re: [IC]Therian40
« Reply #3 on: Sun, 07 February 2021, 18:52:58 »
Great, now it's out there there's no backing down! For both me and you haha
Offline Chippy
  • sus chef
Re: [IC]Therian40
« Reply #4 on: Sun, 07 February 2021, 19:45:50 »
Can you add 10u spacebar compatibility
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline MakerJake
Re: [IC]Therian40
« Reply #5 on: Sun, 07 February 2021, 20:13:08 »
Looks nice Glwic!
Offline JoltFX
Re: [IC]Therian40
« Reply #6 on: Sun, 07 February 2021, 20:20:01 »
Are there plans for a prototype prior to GB
Offline Touch Types
    • Touch Types
Re: [IC]Therian40
« Reply #7 on: Mon, 08 February 2021, 02:51:39 »
There are indeed, i've made one 3dp already and im sending files off for a second in the coming days. After testing the second 3dp model we'll start thinking about machined models.
Offline Touch Types
    • Touch Types
Re: [IC]Therian40
« Reply #8 on: Mon, 08 February 2021, 02:53:18 »
In short, maybe. It may make the bottom row of the plate very open which would lead to alot of flex and potentially a weird sound profile, it's something that can be explored though for sure.
Offline misononyan
Re: [IC]Therian40
« Reply #9 on: Mon, 08 February 2021, 05:42:39 »
ough machining costs
Offline Touch Types
    • Touch Types
Re: [IC]Therian40
« Reply #10 on: Mon, 08 February 2021, 05:46:16 »
They honestly aren't as bad as i had anticipated they would be. Certainly not cheap but not terrible either
Offline DotMatrix
  • Charue Design
    • Charue Design
Re: [IC]Therian40
« Reply #11 on: Mon, 08 February 2021, 12:11:17 »
I like the aesthetic a lot and the way that multiple USB port positions are supported seems pretty cool!
I wouldn't say this is a magnet mounted board right? It's a bit nit-picky but a mounting style is for how a plate is held in place and not how the top and bottom cases are held together.
Either way, looking forward to a prototype!
Offline Touch Types
    • Touch Types
Re: [IC]Therian40
« Reply #12 on: Mon, 08 February 2021, 12:33:22 »
I guess you're right. Couldn't think of a more fitting way to describe it though. If you've got any ideas im all ears.
