Author Topic: [IC] Moesode Bliss  (Read 10921 times)
Offline elli
[IC] Moesode Bliss
« on: Mon, 08 February 2021, 03:20:07 »
261723-0
Featuring OTD-esque design cues in the side profile and the overall top shape, as well as taking it to a calmer and less flashy approach.
Bliss features the DK Saver layout giving us the F13 key, as well as making the spacing equal on the entire top row of the board.
The board features a comfortable typing angle clocking in at 6.5 degrees and the beloved gummy worm o-ring mount.
Slightly altered from the Bliss LE design fixing issues that are apparent in o-ring mounted boards similar to this.
We allowed for room for the o-ring to sit around the spacebar stab in which used to prevent the case from closing previously.
We are also trying to get feedback on whether or not to change the poron strips used as feet to 3M bumpons (SJ5302 specifically).
Price: $450
Mounting: Gummy Worm O-Ring.
Colors: Pink, Blue, Silver, and Black.
Materials: Aluminum Case, Internal Brass Weight, Brass/Stainless Steel Badge.
Typing Angle: 6.5deg
Front Height: 17.8mm
Top Options: Winkey and Winkeyless.
Plate Options: Polypropylene, Aluminum, and Brass. Universal Half and Full Options.
Layout Support: ANSI, Tsangan, and WKL Bottom Row Support. Left and Right Split Shift. ISO Support.
PCB: Custom PCB by Evy, 1.2mm USB C, VIA/QMK Compatible, Custom Pink Pantone Matched Solder Mask.
Sound test of my own personal build that I have been using for a bit now.
Using Cherry Blacks lubed with GHv4 using Gat Yellow springs built on a half polypropylene plate.
Keycaps are OG doubleshots.
Color Guide, Builds, and Color Renders.
Picture of what final pink, blue, and silver colors will look like.
I currently do not have a black board on hand to show for comparison.
Builds from the Bliss LE GB from early on in 2020.
These renders are to give a vague idea of the colors.
« Last Edit: Mon, 08 February 2021, 03:24:22 by elli »
Offline dimo
Re: [IC] Moesode Bliss
« Reply #1 on: Mon, 08 February 2021, 03:26:22 »
pretty in pink
Offline belgium_waffles
« Reply #2 on: Mon, 08 February 2021, 03:33:51 »
Offline VXQN
« Reply #3 on: Mon, 08 February 2021, 04:19:20 »
F13, right side USB port and gummy worm mount? Looks great.
Offline kohalified
« Reply #4 on: Mon, 08 February 2021, 05:14:11 »
this'll be my montage replacement
« Reply #5 on: Mon, 08 February 2021, 08:04:03 »
Takes a tkl like this to catch my eye, v naice
Offline BapoDonu
« Reply #6 on: Mon, 08 February 2021, 08:08:27 »
pink
Offline Friendship
« Reply #7 on: Mon, 08 February 2021, 08:09:15 »
Yes plz :P
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline Reebes
« Reply #8 on: Mon, 08 February 2021, 08:13:29 »
I don’t get it.
Nice board tho! Very pink!
Offline treeleaf64
    • treeleaf64
« Reply #9 on: Mon, 08 February 2021, 14:52:15 »
Everyone must pay the cat tax
Offline Kira
  • <3 <3 <3 <3
« Reply #10 on: Mon, 08 February 2021, 21:21:19 »
Don't say that, I'm sitting here trying to justify another keyboard
Offline firewrath9
« Reply #11 on: Tue, 09 February 2021, 19:53:06 »
gib
ty
Offline MIGHTY CHICKEN
« Reply #12 on: Wed, 10 February 2021, 11:50:56 »
pink pink noice
Offline Tenturo
« Reply #13 on: Fri, 12 February 2021, 23:36:44 »
As someone who owned Bliss LE from the original first run this board is definitely worth it. The sound test is very accurate. Alphas are super poppy, and the o-ring feels great.
Offline marshmellohs
« Reply #14 on: Sat, 13 February 2021, 00:28:56 »
i need this pls and ty <3
Offline Rx003
« Reply #15 on: Fri, 19 February 2021, 05:22:48 »
Bless up glwic
