Author Topic: Anyone recognize this keyboard?  (Read 1728 times)
Offline Lalaland124
« on: Tue, 09 February 2021, 02:30:03 »
Hey I found this keyboard online and could find any information on how rare or good it is.
Maybe someone can tell me what switches it uses :3
Offline yui
Re: Anyone recognize this keyboard?
« Reply #1 on: Tue, 09 February 2021, 08:44:22 »
if you have the keyboard on hand, then try to pull a keycap (very straight, else if it is a mechanical you may break the stem) or try to type on it, if it feels good who cares what it is :)
although if it is tactile, actuate at the end of travel and has a quite rubbery feel on bottom out then it is most likely rubber domes. although no shame in that :) apart from the Zenith keyboards though i never heard of a bull group keyboard that was mechanical so do not get your hopes up though.
Offline Maledicted
« Reply #2 on: Tue, 09 February 2021, 09:49:11 »
Take a look at this.
I have looked at buying a lot of old Zenith boards because we had a lot of their great old tvs growing up. There's not a lot of documentation on most of the later tree logo boards. Z-150 and ZKB-2 (and the 163 model that uses the same chassis) are all Alps linears. ZKB-3 and most other tree logo boards are domes of some kind.
