Author Topic: bBM65 PCB  (Read 7128 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
bBM65 PCB
« on: Tue, 09 February 2021, 20:35:46 »
Spec
1\65% Layout with 67 keys(BM65 doesnt mean the pcb only has 65 keys, 65% is size type)
2\Fully programmable PCB(QMK and VIA supported)
3\Full hot swappable switch sockets
4\Full RGB switches Leds(With kinds of LED effects)
5\6 bottom RGB underglow leds(pre-soldered)
6\MX Stem support
7\All components of the board have been pre-soldered so the PCB is ready for key switches and LEDs
8\Type C port
purchase
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: bBM65 PCB
« Reply #1 on: Tue, 09 February 2021, 20:36:58 »
