Author Topic: KO NO DIO DA! Interesting keyboard from China  (Read 29232 times)
Offline MIC_David
« on: Wed, 10 February 2021, 11:27:22 »
Hello everyone. I'm a keyboard lover from China and this is the first time I use this bbs.
I want to show you an interesting keyboard from China called DIO V2 R2.
The name of the keyboard is from animation JoJo's Bizarre Adventure.
It is a very nice keyboard and it is made with exquisite workmanship.
If you want to buy one, you can leave a message below, the price of it is 370$.
Offline mutthunt
Re: KO NO DIO DA! Interesting keyboard from China
« Reply #1 on: Wed, 10 February 2021, 12:36:36 »
Great layout, is there any more info on it?
Offline MIC_David
« Reply #2 on: Wed, 10 February 2021, 23:48:00 »
Of cause, but my english maybe not very good so some words might not be accurate.
It has hot swap pcb you can easily change switch you like.
The positioning plate is made of aluminium.
The little screen on the the top right-hand corner is a light bar. You can change the sheet metal on the light bar to change the words of the screen. (It needs you DIY) And the little screen is magnetic fixation means you can easily open it.
PCB is type C slot.
Offline Rayndalf
« Reply #3 on: Thu, 11 February 2021, 00:39:11 »
Since this is a new product it might be better to create a post in the group buy section (unless you're unaffiliated with the designer of the board, in which case you should ask them to create an interest check or group buy post).
Looks like a nice board. If I find money I might like to purchase one.
Offline MIC_David
« Reply #4 on: Thu, 11 February 2021, 02:20:12 »
Actually the group buy of this keyboard is ended. I'm not the designer so I won't create group buy post. If there are many people like this keyboard, I will discuss with the disigner to create a formol post. THX your advice.
Offline Rayndalf
« Reply #5 on: Thu, 11 February 2021, 02:50:58 »
So the group buy period has ended but some boards can still be purchased? Any idea what colors are still available?
I'm not sure, but it might be okay for the designer to make a group buy thread for the extras. I think.
Offline MIC_David
« Reply #6 on: Thu, 11 February 2021, 11:50:42 »
I have contact with the designer and he agree to create a post on interest check.
This is the post: https://geekhack.org/index.php?topic=111164.msg3012855#msg3012855
Thanks your advice again sincerely.
Offline dlgusgh
« Reply #8 on: Sat, 20 February 2021, 02:57:25 »
Hi, I really want to buy this keyboard! I love the design! Is there any way to still get it?
Offline MIC_David
« Reply #9 on: Tue, 23 February 2021, 12:21:23 »
The red one is really cool, isn't it?
Offline MIC_David
« Reply #10 on: Tue, 23 February 2021, 12:23:39 »
If you wanna buy one you can contact with me by private chat.
Offline rainb1ood
  • so pretty so plastic
« Reply #11 on: Tue, 23 February 2021, 12:38:19 »
does it come with stand
Offline MIC_David
« Reply #12 on: Tue, 23 February 2021, 23:19:43 »
No, it can't adjust the height. I'm sorry.
Offline MIC_David
« Reply #13 on: Fri, 26 February 2021, 20:32:06 »
If you want to buy one,  you can contact with me by discord
My id is BRCOM_David#4438
Offline toufusoup
« Reply #14 on: Sun, 07 March 2021, 20:59:09 »
I added you via toufusoup#5000 on Discord to ask a few questions, hope that's alright
