Author Topic: Sharkoon Fireglider  (Read 10850 times)
Offline Irie
Sharkoon Fireglider
« on: Wed, 11 August 2010, 15:57:01 »
anyone able to give an experience report on this mouse?
Features:
• Laser mouse with 7 buttons (6 of them freely programmable)
• DPI switch with color display (6 steps)
• Weight tuning system (max. 19.5 g)
• On-board memory for macros
• Smooth running and finely adjustable scroll wheel
• Ergonomic design for convenient handling
• Special grip areas offering maximum hold
• Ideal for professional applications and gaming
• Supported operating systems: Windows XP/Vista/7 (32 and 64 bit)
Specifications:
• Max. DPI/CPI: 3600
• DPI/CPI stepping: 100 - 400 - 600 - 800 - 1200 - 1600 - 2000 - 2500 - 3600
• Max. acceleration: 20 G
• Mouse weight max.: 135 g
• Mouse weight min.: 118 g
• Laser sensor: Agilent ADNS-6010
• Connector: USB (cable length: 1.8 m)
• Power input: 5V - 60 mA
Delivery includes:
• FireGlider Black
• CD with software and manual (as PDF)
• additional mouse skates
• transport bag
SOURCE: http://www.sharkoon.com/html/produkte/eingabegeraete/fireglider_black/index_en.html?id=firgl_bl
Offline Scarzy
    • http://enecutive.blogspot.com/
Sharkoon Fireglider
« Reply #1 on: Thu, 12 August 2010, 17:49:08 »
It's made by Sharkoon, it's going to be pretty bad and put with stupid, non-needed features, slightly like the '3 clicks in one' button on A4 tech gaming mice. DPI is far too high. Go for something by Microsoft (IME3) (WMO) (IME1.1) if you don't need a top notch gaming mouse.
Offline Bullveyr
Sharkoon Fireglider
« Reply #2 on: Fri, 13 August 2010, 05:00:30 »
Actually it's made by A4Tech.
From what I have heared from a couple of people it's a decent mouse with the probably most advanced macro software.
Quote from: ripster;185750
Mechanical switches are mechanical.
Offline troopZ
Sharkoon Fireglider
« Reply #3 on: Sun, 15 August 2010, 20:31:58 »
Well I have just the Fireglider, not black and to be honest its the best mouse I've ever used and it only cost me $49.95AU !
Offline hyperlinked
Sharkoon Fireglider
« Reply #4 on: Sun, 15 August 2010, 21:03:07 »
Hmmm... Anytime I hear of a good 7 button mouse, my ears perk up. I don't game anymore, but I have keys mapped to my extra mouse buttons to speed up my workflow when I'm programming and doing graphic design and I need at least five easy to reach buttons for a good setup. It's amazing what being able to hit the "Enter" key on your mouse will do to speed things up. You don't have to take your hand off the mouse to confirm a default option prompt or to save a file download under its default name.
From that angle it looks like it has a similar profile to the Razer Diamondback/Copperhead/etc. series which I like a lot. Where are the buttons located? Where can one get a hold of one of these in the States? I've never heard of the name Sharkoon before.
Maybe it's not so much like the Diamondback series...
It's actually almost the exact same shape as my current mouse, a Razer Imperator except it looks like it might have some more rubberized spots. Curiously, the Imperator has no rubberized grip areas. I grip it just fine without them, but it'd feel nicer if it had some rubber strips for fingertip grip traction.
« Last Edit: Sun, 15 August 2010, 21:14:51 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Bullveyr
Sharkoon Fireglider
« Reply #5 on: Mon, 16 August 2010, 02:44:09 »
The Fireglider is a rebranded A4Tech XL-740K, you can even use the A4Tech Drivers.
The X-748K is the optical version.
I guess the A4Techs should be easier to find in the States.
Offline Bullveyr
Sharkoon Fireglider
« Reply #6 on: Tue, 17 August 2010, 01:46:43 »
Because A4Tech thinks it's usefull and it's actually pretty cheap.
Offline Oqsy
Sharkoon Fireglider
« Reply #7 on: Tue, 17 August 2010, 03:25:34 »
Sorry, the title of this thread and the name of this product sounds like a Star Wars vehicle.  My gut feeling is a single man vehicle somewhere between a speeder bike (on the Forest Moon of Endor in ROTJ) and a STAP (hovering battle droid Segway)
The influence of Ripster is strong in this thread.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline alec
Sharkoon Fireglider
« Reply #8 on: Tue, 17 August 2010, 06:50:11 »
this is A4tech XL-740 mouse with a fancy name
Noppoo Choc Mini
Sharkoon Fireglider
« Reply #9 on: Tue, 17 August 2010, 09:56:34 »
So that is why I thought I had seen it before ...
Sharkooooooon. I wonder what that is. A shark that moves as fast as a typhoon? A typhoon of sharks?
And how do you glide on fire?
« Last Edit: Tue, 17 August 2010, 10:00:34 by Findecanor »
Offline Oqsy
Sharkoon Fireglider
« Reply #10 on: Tue, 17 August 2010, 22:29:13 »
Quote from: Findecanor;213466
Use the force, Luke.
Offline Irie
Sharkoon Fireglider
« Reply #11 on: Fri, 03 September 2010, 18:56:31 »
ive bought the mouse and i gotta say im pretty amazed by it. its very cheap (27€) and performs ultra well. 6 different DPI settings, i really like the 400dpi one.
nice gliding on the mouse pad due to its low traction. it even comes with two extra sets of mouse skates.
my gaming performance has increased from the get-go, no adjusting difficulties.
downside is the thumb buttons which do require some getting used to. their positon is a little high for my taste.
i would definetely recommend the mouse to other gamers.
Offline Irie
Sharkoon Fireglider
« Reply #12 on: Fri, 03 September 2010, 19:10:41 »
i never said i was too poor, just didnt wanna spend 200€ on a keyboard. whats wrong about paying 27€ for a freaking mouse, rippy mon, my deary?
find me a decent black mechanical board for 50€ and german layout and ll go for it :D
Offline Irie
Sharkoon Fireglider
« Reply #13 on: Fri, 03 September 2010, 19:21:13 »
i remember that. i also remember remember that you got that wrong in the thread some time ago :D
i took it the guy was asking how much the keyboard cost so i answered 20€. i believe you thought i was only gonna spend that much on a keyboard. that wasnt what i meant tho. i just went for the cheap one because it got really good test score on testeo.de and was very cheap. since i needed one desperately, it was perfect. its pretty much the same as my old one but has better quality.
still willing to try mechs tho
hope we get each other now? ;)
Offline Irie
Sharkoon Fireglider
« Reply #14 on: Sat, 04 September 2010, 07:12:04 »
wow, last time i visited my hood shops about keyboards they all told me that they had no mechs in stock. when i asked them about the pricing of ordering one, they told me the cheapest one sells for 80€. that being a cherry i wonder why the one you posted is so much cheaper - 50% actually.
ill fetch one of those when i get a chance. that does seem really cheap for a mech
Offline Irie
Sharkoon Fireglider
« Reply #15 on: Sat, 04 September 2010, 08:21:54 »
i just tried the software settings for the mouse. its pretty effing good tbh. DPI setting are freely adjustable! you can programme each mouse button except for the DPI button freely on a very advanced, funtional, and intuitive user interface
Offline Bullveyr
Sharkoon Fireglider
« Reply #16 on: Sat, 04 September 2010, 11:57:58 »
Yep, A4Tech has the most advanced software.
