Author Topic: Which would you rather get if they were both available?  (Read 3078 times)
Offline sneakysnek
« on: Sun, 14 February 2021, 11:37:53 »
SAKA68 or VEGA65?
Thinking about getting the SAKA68 e-white with the brass plate but i've seen the vega and there's apparently 'no bad sounding vega'.
Let me know your thoughts please!
Offline Slayer77
Re: Which would you rather get if they were both available?
« Reply #1 on: Wed, 17 February 2021, 23:09:10 »
You can't compare the 2 they are in different budget categories, saka68 being mid range while Vega is on the higher end.
Sent from my GM1911 using Tapatalk
Offline Rx003
« Reply #2 on: Fri, 19 February 2021, 01:49:36 »
I would go for Vega, not to be bias (as I own one) But the typing feel is so great, build itself is pretty solid, and it sounds really good with or without foam but if for budget yes Saka is a good choice.
