Author Topic: Tool for Programming QMK Key Codes  (Read 3439 times)
Offline azzipa
« on: Mon, 15 February 2021, 12:00:57 »
If you're interested in programming non-standard keys and/or macros, this is a helpful tool called Key Codes from programmer Many Tricks. "Key Codes is a little utility that displays the key code, unicode value, and modifier keys state for any key combination you press. If you're a developer, this might be useful to you." (I have no involvement, just found this helpful.)
« Last Edit: Tue, 16 February 2021, 06:56:18 by azzipa »
Offline xudongz
    • Personal Site
Re: QMK - Programming Key Codes
« Reply #1 on: Mon, 15 February 2021, 12:03:27 »
Just to add on, Linux users might be interested in the "xev" command.
To monitor all input events:
Code: [Select]
xev
To monitor just keyboard events:
Code: [Select]
xev -event keyboard
« Last Edit: Mon, 15 February 2021, 12:07:27 by xudongz »
SliceMK | ErgoDox Wireless group buy round 2 running until November 16, 2021
Offline Faceman76
« Reply #2 on: Mon, 15 February 2021, 12:06:15 »
Thanks, I'm looking to re-purpose several keys to Copy & Paste.  I know about Cont+C & Control+V, but when you're using both sometimes several hundred times in a row, this will save time.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
