Author Topic: Does anyone have a downloadable render template for TLK and 60& keycap  (Read 3393 times)
Offline MrBoron
Im looking to design my own keycaps and am struggling to find a render template, im looking for GMK template if that makes a difference.
I cant be bothered making the keycaps from scratch.
if anyone has one that would be great.
Offline OnlyFan
Re: Does anyone have a downloadable render template for TLK and 60& keycap
« Reply #1 on: Wed, 17 March 2021, 03:39:20 »
This might be what you're looking for.
https://www.dakotafelder.com/keycap-designer-resources
Offline hnry
« Reply #2 on: Mon, 12 April 2021, 11:58:28 »
https://gumroad.com/l/KeyboardRenderKit/
It is an amazing source that helps me make kits :) the $36 is SO worth it if you’re serious about designing keycaps.
