Author Topic: [IC] Keydelabra - Artisan Keycap Stand  (Read 7870 times)
Offline samsamm777
    • Superhuman Keyboards
« on: Sun, 21 February 2021, 11:36:54 »
IC Form
Hello everyone!
I'd like to introduce the Keydelabra (a candelabra, for keycaps!)
I've struggled to find a good solution for displaying my artisan keycaps, and figured id share my idea with everyone.
This hopefully wont be a group buy. Depending on costs we will aim for this to be an in-stock item with no pre-order required.
Renders
Follow our instagram for more updates
http://instagram.com/superhumankeyboards
TODO:
Pricing
Vendor
Stock Date
Thanks for your interest, and we would love to hear your feedback!
« Last Edit: Mon, 22 February 2021, 12:01:13 by samsamm777 »
Offline MIGHTY CHICKEN
Re: [IC] Keydelabra - Artisan Keycap Stand
« Reply #1 on: Sun, 21 February 2021, 11:37:27 »
Interesting to say the least
Offline NotYeMK
  • I will yeet your keyboard
« Reply #2 on: Sun, 21 February 2021, 11:43:24 »
Should also include adapters that would allow Topre or add an angle to the stand.
Offline samsamm777
« Reply #3 on: Sun, 21 February 2021, 11:46:03 »
Im experimenting with a slight angle, im going to be 3D printing some prototypes soon, so i may update with an angle if it works better. I'll keep you posted, its a good idea.
Offline mfwit
« Reply #4 on: Mon, 22 February 2021, 07:26:57 »
Been looking for something like this for taking photos of artisans. Give me the ability to angle them and I'm in for a few!
Offline samsamm777
« Reply #5 on: Mon, 22 February 2021, 09:50:27 »
I'm going to go back and rethink this a bit, i really appreicate the feedback, and i have some ideas on how to make this work. I'll update this IC with new artwork soon!
Offline samsamm777
« Reply #6 on: Mon, 22 February 2021, 11:45:56 »
Update - Keydelabra v2
Given the feedback, i have improved on the design to allow for flexible keycap positions, and also allows for different keycap connectors.
Rotational Mechanism
Inspired by stands for X-Wing board game, using strong neodynium magnets and a ball bearing.
Its possible to provide a very flexible positioning mechanism for your keycap on the stand. This then will suite a much wider variety of needs and scenarios for your stand display.
Please see main post for updated renders.
Next Steps
I am going to prototype this new design to find out the maximum keycap weight of the mechanism. This will dictate how well the positioning will perform.
Interest Check Google Form
https://docs.google.com/forms/d/e/1FAIpQLScoEF3BC2jhYDeI9ePUZ3ZP4Ixc1dz7QxouCRCbMGsd7HrJ5w/viewform?usp=sf_link
« Last Edit: Mon, 22 February 2021, 12:01:47 by samsamm777 »
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #7 on: Mon, 22 February 2021, 12:11:25 »
Next Steps
Removing this. Apologies.
« Last Edit: Mon, 22 February 2021, 17:40:37 by loop | esc lab »
  • Formerly 'esclab'
    • esc lab
« Reply #8 on: Mon, 22 February 2021, 12:19:16 »
In terms of feedback/suggestions, I highly recommend using some sort of soft rubber (or material) to minimize the damage or scratches that could happen onto an artisan stem.
I collect artisans myself and I would be afraid to use something that's too hard that might potential scratch my keycap.
The rotating mechanism sounds very interesting but I wonder if too many rotational position possibilities will make it hard to match if you have a lot of artisans?
Other than that, this is dope. I'm definitely down to get some.
Any pricing expectations?
Offline TheInverseKey
  • You can run but you cannot hide!
« Reply #9 on: Mon, 22 February 2021, 15:19:15 »
Looks like I floated a value better check the LS.
Offline o3okevin
« Reply #10 on: Mon, 22 February 2021, 15:48:29 »
This is beautiful! I imagine this will pair perfectly with Series 00.
Pretty bad taste to advertise your own stuff in another IC
Offline samsamm777
« Reply #11 on: Mon, 22 February 2021, 16:40:41 »
My dude, can you explain what you mean? I dont know the lingo  ;D
Offline Nuap
« Reply #12 on: Mon, 22 February 2021, 17:35:41 »
Please don't hijack other peoples threads to advertise your GB.
  • Formerly 'esclab'
    • esc lab
« Reply #13 on: Mon, 22 February 2021, 18:01:08 »
I removed it and apologized to OP. Thanks for bringing it up.
Offline samsamm777
« Reply #14 on: Tue, 23 February 2021, 05:12:13 »
Thanks, appreciate you reaching out.
Offline Chippy
  • sus chef
« Reply #15 on: Tue, 23 February 2021, 23:41:07 »
This is incredibly unnecessary. I love it.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline samsamm777
« Reply #16 on: Sat, 17 April 2021, 07:24:03 »
Bumping this thread, as its been a while. (Hope im not break rules)
