Author Topic: [IC] Fox Lab - Leaf 65%  (Read 116295 times)
Offline SekaiJutsu
    • GeekHack
Re: [IC] Fox Lab - Leaf 65%
« Reply #250 on: Thu, 08 April 2021, 19:01:54 »
Can we get a Red/ darker red colorway? Sad that the Time80RE didn't offer it when the GB was up
Offline Jet1370
« Reply #251 on: Thu, 08 April 2021, 19:12:55 »
Is there a place to find what the different color options look like exactly?  I see that you can select the different colors from the website but I was hoping to get the light blue color but am not sure which one that is.
Offline CookieFlow
« Reply #252 on: Thu, 08 April 2021, 21:06:45 »
Edit:Found the info I needed
« Last Edit: Fri, 09 April 2021, 17:40:46 by CookieFlow »
Offline NixieTea
« Reply #253 on: Thu, 08 April 2021, 23:53:25 »
Is the GB still planned to run this week, or is it delayed?
Offline NixieTea
« Reply #254 on: Fri, 09 April 2021, 01:04:39 »
I’m dumb, haha. According to insta, GB starts today at 8 PM ET
Offline mcheddadi
« Reply #255 on: Fri, 09 April 2021, 02:36:37 »
Here's some nice high quality pics of the leaf65 protos. Don't know why these haven't been posted yet...
https://www.zfrontier.com/app/flow/45aqZ63Yn85J
Offline prognostics
« Reply #256 on: Fri, 09 April 2021, 06:52:34 »
Thank you for updating those of us on GH who aren't on IG :thumb:
Posting the full comment from his new post: "fox_lab_keyboard
Leaf65 GB starts on April 9th at 8 PM ET and will last 1 week. The link in bio will work then."
« Last Edit: Fri, 09 April 2021, 06:56:30 by prognostics »
Offline 8six753o9
« Reply #257 on: Fri, 09 April 2021, 10:02:54 »
Hi Senter,
Would we be allowed to buy an extra badge in different color?  I would love to do a 2-tone board like the lilac sample you had in the original post but it looks like the weight and badge will be the same color in the store.
Offline ZongZiWang
« Reply #258 on: Fri, 09 April 2021, 12:04:56 »
Same question as above, if you cannot chose different color for front logo and bottom weight, it seems to me less attractive to have different top and bottom cases for the two tone feeling.
Also some good options of “what can be achieved” in the IC are not available during group buy (I’d like to have the lilac and the modern dolch gray+teal colors), which is a huge bummer.
Offline leexy
Re: [IC] Fox Lab - Leaf 65% (need feedbacks on plate design revisions)
« Reply #259 on: Fri, 09 April 2021, 12:40:18 »
FR4 is the only option doesn't fit the rule that the plate and weight must be in the same material and color. I really suggest you to try the default skeleton plate or pay $25 more for an extra FR4 one.
hi senter, skeleton plate was not available during CN gb? will it be available as extras?
also, as someone asked before, will pcbs be compatible with key65?
Offline succulentdan
« Reply #260 on: Fri, 09 April 2021, 13:20:24 »
I'm curious how the board sounds without foam? I've seen minterly's review and taeha's build where he mentioned it sounds a bit muted with the foam installed. I'm curious if the foam was added later in the design, or always an intended part. Definitely loving the design and color options but at $415, i'm just a bitttt on the fence.
Offline _Harrison
« Reply #261 on: Fri, 09 April 2021, 13:31:56 »
Looking for another 65 board and this is so clean!
Count me in :)
Offline ZongZiWang
« Reply #262 on: Fri, 09 April 2021, 13:40:19 »
Me, too. Hope there are streamers or prototypes out there without foam to show how does that sound.
Offline senter
« Reply #263 on: Fri, 09 April 2021, 18:59:02 »
GB starts now. I'll answer questions here: https://geekhack.org/index.php?topic=112202.0
