Author Topic: Number-row-less TKL  (Read 3335 times)
Offline shanekeeber
Number-row-less TKL
« on: Wed, 24 February 2021, 15:27:20 »
I got some inspiration from the Onyx FRL TKL, and decided to take it to a new, very impractical level. I saw the 4 macro keys on the left side of the Onyx, and thought: why not make it all 12 function keys, and then remove the number row?
So it's basically some botched 40% layout, with arrow keys and 2 media keys (that could maybe be programmed to volume up and down or something) stitched onto the right, and the function row piled into a 3x4 cluster on the left.
I had 2 versions in mind, the default NRL(numrowless) TKL, and PP NRL TKL.
The default layout features Delete and End, horizontally.
262997-0
The PP version features PgUp and PgDn vertically.
262999-1
All feedback is welcome, thanks for looking at this stupid board.  ;D
Offline Pwner
  • soon™
Re: Number-row-less TKL
« Reply #1 on: Thu, 25 February 2021, 02:47:59 »
Will the PCB have ESD protection?
« Reply #2 on: Thu, 25 February 2021, 06:56:08 »
The alpha section is wider than a normal keyboard, and I'm afraid that the far-right 1u Backspace and far-right Enter key would put people off. That section is 3u wider than a 40%!
Why not have a full 6-key cluster on the right?
Offline ddrfraser1
  • RIP Neil
« Reply #3 on: Thu, 25 February 2021, 07:07:14 »
I see your odd and whacky 40 and raise you my odd and whacky (not) 40
263017-0
« Last Edit: Thu, 25 February 2021, 07:09:05 by ddrfraser1 »
« Reply #4 on: Thu, 25 February 2021, 10:19:03 »
I like this: functional and unique.
Sent from my Pixel 4 using Tapatalk
Offline AuthenticDanger
« Reply #5 on: Thu, 25 February 2021, 11:02:56 »
I don't know if I like the face or the penis on the right side more. I'll have to think about it.
F Keys belong on the left.
Offline azzipa
« Reply #6 on: Thu, 25 February 2021, 11:24:18 »
this.
Offline treeleaf64
    • treeleaf64
« Reply #7 on: Thu, 25 February 2021, 11:26:44 »
I dont know if you are going to find the correct keycap for the left part with the macros
Everyone must pay the cat tax
Offline azzipa
« Reply #8 on: Thu, 25 February 2021, 11:31:51 »
I dont treeleaf doesn't know if you are going to find the correct keycap for the left part with the macros
fify  :D
Offline phinix
« Reply #9 on: Fri, 05 March 2021, 15:53:58 »
I never understood purpose of 40% keyboards...
Why would someone want a number less keyboard?
