Author Topic: [GB]MG Ghost Keycaps (25th Feb ---> 15th Mar)  (Read 12022 times)
Offline York Chan
« on: Sat, 27 February 2021, 04:30:08 »
MG Ghost
Halo, this is York. This time MG PROFILE design was inspired by Pokémon's GENGAR.  :thumb:
Purchase link: https://www.melgeek.com/collections/group-buy/products/gb-melgeek-mg-ghost-abs-doubleshot-custom-keycap-set-melgeek-com
Group buy starts on 25th.February 2021, ends on 15th.March 2021.
Leadtime: 6 months.
Inspiration
The color scheme is inspired by the Gengar.
Render
Layout
Specs
  • MG profile(1-1-2-3-4-3)
  • Doubleshot ABS
  • Designed by York Chan, produced by MelGeek
Contact
Discord:https://discord.com/invite/EGjbcDR
Please consider adding this to your signature to support the set:
Code:
Code: [Select]
[url=https://geekhack.org/index.php?topic=110791.0][img]https://i.imgur.com/jbi6UBS.png[/img][/url]
« Last Edit: Mon, 01 March 2021, 05:40:13 by York Chan »
Offline Darth_munkee
Re: [GB]MG Ghost
« Reply #1 on: Sat, 27 February 2021, 22:06:39 »
Great looking set. I wish it had some ortho support but maybe if there is a next time.
Offline York Chan
Re: [GB]MG Ghost
« Reply #2 on: Mon, 01 March 2021, 05:38:26 »
Thank you for your support :thumb:
Offline Pigpen
Re: [GB]MG Ghost Keycaps (25th Feb ---> 15th Mar)
« Reply #3 on: Mon, 01 March 2021, 10:15:04 »
I'm in....Gotta catch em' all. I love the profile ordered all 4 options
Offline Pigpen
« Reply #4 on: Mon, 01 March 2021, 10:27:31 »
Is there any plans for cable, deskmat, Rama or Collabs?
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #5 on: Mon, 01 March 2021, 23:48:55 »
Offline York Chan
« Reply #6 on: Sat, 06 March 2021, 03:20:47 »
There is no plan for the moment
Offline Havattack
« Reply #7 on: Sat, 06 March 2021, 18:46:35 »
"Laser" themed cables will work perfect for this. As for a deskmat, just find a cool Gengar (or whatever you want) wallpaper you like, resize it and have one of the many custom desk matt companies make you one, it's like 40$.
Offline jellyrole
« Reply #8 on: Tue, 09 March 2021, 11:46:14 »
Is there a place get to get smaller space keys with the same profile and color for this set?
Offline dvorcol
« Reply #9 on: Mon, 15 March 2021, 14:00:46 »
Edit: added history
« Last Edit: Wed, 22 April 2026, 22:51:17 by dvorcol »
Offline Havattack
« Reply #10 on: Mon, 15 March 2021, 17:23:25 »
As far as I know, not the same exact profile, MG is pretty new, but SA is pretty close. I don't think you'd notice a difference visually if you had an SA key mixed in with the MG. But from the quick search I just did, I couldn't find any individual SA keys in a pink color. So, as far as i know, you are probably going to have to settle for a smaller, more common, profile. Or maybe get a matching colored resin space bar? Personally, I don't think the space bar being a different form is going to make a big difference.
What size key do you need exactly? I'll keep a eye out and let you know if i come across something.
Offline jellyrole
« Reply #11 on: Mon, 15 March 2021, 20:08:02 »
Thanks for the response, it's actually a split space bar with 3 keys - the split is 1.25 + 2.25 + 2.75
Offline jellyrole
« Reply #12 on: Thu, 12 August 2021, 19:32:54 »
Anyone else have any ideas for split space bar keys for the MG style?
