Author Topic: Hello from California!  (Read 1803 times)
Offline djindoe
« on: Wed, 03 March 2021, 01:32:29 »
Hello all! I started my mechanical keyboard journey about 11 years ago when I got my first DasKeyboard. After a few more Corsairs and DasKeyboards and being rather unimpressed over the years, I decided it was finally time to go down the rabbit hole. Here's what I'm working with so far:
1) Keychron K6
- Gateron Red (lubed) - Alphas
- Cherry Pinks (lubed) - mods
- Cherry OEM stabs
- Artifact Bloom Matcha Mango PBT caps
2) Epomaker Niz Plum Atom66
- 35g dome sheet
3) Epomaker GK96S
- Gateron Red (stock)
Really just looking to mess around with the more budget and experimenting with other switch types before I do a fully custom build. Looking forward to meeting all of you and learning more about this weird hobby we share.
Keychron K6
Niz Plum Atom66
Epomaker GK96S
Offline Maledicted
Re: Hello from California!
« Reply #1 on: Wed, 03 March 2021, 13:08:35 »
Hi djindoe. Welcome to Geekhack.
Those keychrons seem like great boards for what they are.
By MX pink, do you mean silent reds? Sounds like a good combination (even coming from a clicky guy). Silent reds are surprisingly smooth and pleasant.
how do you like the Niz switches? I have only tried 55g Topre.
I'm using a Das Pro 4 with box navies in it at this very moment, and own piles of Corsairs that I love.  :p
Offline djindoe
« Reply #2 on: Fri, 05 March 2021, 10:16:18 »
Keychron and Epomaker seem to be 2 of the better options on the more budget side when starting out. They're pretty low cost and easy to mod so you don't feel bad experimenting on them. That way, whenever I decide to do my first full custom, I'll already have a really good idea of what I want.
Yup, the pinks I'm referring to are the Cherry Silent Reds. I found them to be pretty scratchy with noticeable spring ping when I first got them. A little bit of lubed solved both.
I personally like the Niz switches. These ones are extremely light, but I prefer excessively light switches. However, even at 35g, there's still a good amount of tactility.
Keychron K6
Niz Plum Atom66
Epomaker GK96S
Offline Maledicted
« Reply #3 on: Fri, 05 March 2021, 11:56:19 »
I think cheap boards are great for anybody who wants to tinker and/or have something they don't care about beating up, losing, etc. Personally, I love modifying OEM boards to make them something unique.
You're wise to get a good feel for your switch tastes before investing a lot of money into something specific, especially if you're not using hot swap sockets (which I prefer to use only for testing different switches myself).
I imagine that comparing them to Gateron reds without any inferior point of reference, they would seem scratchy. They're smoother right out of the gate than MX red and most other cheap Chinese clones though, for whatever reason.
My favorite modern dampened linears, of the few I have tried, are Matias' "quiet linear" switches myself. But they seem to me to actually have a tactile event at the end of travel right before bottoming out. They seem very smooth to me, but I have never bothered to lube anything either. I think they're factory lubricated. Also, being a clicky guy, I specifically like pretty sharp tactility.
I need to try some Niz switches ... and Topre lighter than my 55g board for that matter.
