Author Topic: [IC] GMK Wasabi V2 (Live)  (Read 44181 times)
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [IC] GMK Wasabi V2
« Reply #50 on: Thu, 11 March 2021, 11:49:26 »
If a second base for latin alphas is feasible, what are the chances of that base kit having a numpad? While I can't speak for other V1 owners I know I'd love to be able to get the numpad keys without having to buy the V2 Hiragana base. I was planning on getting the Latin alphas & spacebar kit to pair with my V1 set, but would actually prefer to be able to get a V2 Latin base with a numpad & spacebar kit over that. Since this time around the set is using text + icon mods, V1 owners would be able to get full layout support without having to buy any duplicate keys that way.
I both understand and appreciate you trying to complete you first run. This version is not meant for that purpose though, it's more of a stand alone run or a second version, like most other second versions or runs. Moving B to spacebar kit was a good suggestion, and that is under consideration, as it makes sense, of course, facilitating Alice support for potential R1.
A second base is not something feasible for this run, as I would rather run one well priced base, at a decent moq with supporting kits, for those that would like a little more. Being that the subs of this set are what the main idea is, I would like to not distract from that. If they were different colored bases or offered something else, I feel it would make more sense in that situation, and would have been done.
Could potentially look into adding an icon only tab to the Latin kit, possibly making that a little more friendly for R1 buyers, being able to outfit a couple boards with their R1 + Latin, that way and still have a matching tab (if that sounds like a good idea? Maybe a nice middle ground? Doesn't address the numpad, but I will not be splitting that from base, sorry), otherwise, building kits around R1 - what it had and didn't, doesn't seem like the most sound idea to me, first run was quite a while ago now. - Why you make me type so much Rob? :D Appreciate you! <3
 :p Sorry bud, just was spitballing an ideal since I seen others were asking about a Latin base. I get it though, most of my ideals would add unneeded complexity or drive costs up to point where it wouldn't be worth running that way. You know much better than I would what is needed to make the GB go smooth, so I'm down with whatever you do man!
« Last Edit: Tue, 23 March 2021, 00:42:49 by Rob27shred »
Offline XiXora
« Reply #51 on: Thu, 11 March 2021, 20:36:15 »
UK ISO doesn't tend to happen for Japanese legend-based kits or does it?
Main reason why I copped Dandy (other than my love for green).
I do appreciate the 1.5u super 2x 1u alts though.
Offline guybrush
« Reply #52 on: Sat, 13 March 2021, 13:37:15 »
Any plans for Rama/Salvun artisans?
Offline JQ27
« Reply #53 on: Sat, 13 March 2021, 18:55:26 »
So many sets I would have questionable financial decisions on if they included UK ISO :(
Offline sourmk
« Reply #54 on: Mon, 22 March 2021, 13:11:36 »
Good day!
Had originally planned to collab with Rama on this petal design with the first Wasabi buy back in 2019, so to say I'm excited is an understatement.
RW X Wasabi
In other updates, Base and Spacebar kits have gone in for re-quotes. Updates soon! Buy goes live in a couple weeks!!
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline Tyson
« Reply #55 on: Mon, 22 March 2021, 21:58:11 »
Good day!
RW X Wasabi
These look sooooooooo clean! Can't wait for this set!!!
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #56 on: Mon, 22 March 2021, 23:32:52 »
I may have to join this one. Wasabi v1 ran before I was in the hobby, and I'm not keen on waiting another few years until it may be available again :P
Offline sourmk
Re: [IC] GMK Wasabi V2 (Live April 4th)
« Reply #57 on: Thu, 25 March 2021, 14:43:23 »
Hello! Kitting has been finalized. Going live on April 4th!!
Offline SerialWaffle
« Reply #58 on: Sun, 04 April 2021, 17:11:31 »
Is this going live today?
Offline sourmk
« Reply #59 on: Sun, 04 April 2021, 18:02:11 »
Tomorrow, the 5th :thumb:
Offline sourmk
Re: [IC] GMK Wasabi V2 (Live)
« Reply #60 on: Mon, 05 April 2021, 04:33:51 »
Some vendors have started going live.
GB thread is pending approval :thumb:
Offline SwitchKeys
    • SwitchKeys
« Reply #61 on: Mon, 05 April 2021, 06:12:47 »
Let's go Sour! Pleasure to be back at it with you.
Offline Rob27shred
« Reply #62 on: Mon, 05 April 2021, 06:43:53 »
V2 Let's goooooooo! Good luck with the GB bro!
Offline jadech
« Reply #63 on: Mon, 05 April 2021, 12:57:05 »
Grabbed the RAMAs! Amazing set
