Author Topic: [IC] PooPooPeePee Keyboard Carnival Round Three (UPDATED 7/18/21)  (Read 45926 times)
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
AKA P4kcr3. (pronounced however you feel like it)
A warning to the normies,  this post is brought to you by the 40's discord
        :( when gh wont let you format youtube videos
IC Form here
Design
I was inspired to make this keyboard after I modded my minivan case by removing the center 3 standoffs,
this creates a bouncy typing feel under the most centered alphas, which is quite nice.
However it still had hard tray mount feels around the mounting points,
which strangely encroach on the punctuation cluster, this made me hunger for more flex.
The hunger lead me to design the P⁴KCR3, a plateless, gasket mount, milled POM case,
that utilizes the edges of the PCB, and some gorilla gripp’n strips of silicone foam
to produce an extremely bouncy board.
This board mimics and expands on the benefits of the modded tray mount minivan,
while eliminating much of the harshness and inconsistent hard spots.
Whats new
Prototypes have been produced with the following features:
  • Side angles have increased from 90d to 85d, decreasing the slope
  • The top edge fillet has been increased from a 1mm to a 4mm radius
The typing feel is extremely bouncy in the center,
while the mods still retain enough stiffness under them for a solid bottom out.
Pricing and SKU
  • the board will be offered in a white POM top, and brass bottom, both parts will be sandblasted
  • the SKU offered will be chosen based on the options listed in the IC form
  • for the case, and required hardware/gaskets, the price is undetermined.
An Assembly guide of the prototype
Join my Discord for the most up to date info
some community feedback. thanks to Sumthing.
add this text for marge flair in your signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=111567.0][img width=640 height=487]https://imgur.com/nkarDug.jpg[/img][/url]
« Last Edit: Mon, 26 July 2021, 00:32:35 by Heist Morty »
Offline MIGHTY CHICKEN
Top Tier
Offline dingusxmcgee
Really beautiful name. Truly original and descriptive.
Offline Sumthingasian
Support your local PooPooPeePee Keyboard Carnival Round Three man
Offline Chippy
  • sus chef
can we get a render with gmk pooped in the pool?
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Bregoli
pee pee poo poo!
Offline Izeri
Such a good name
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
Yes
Courtesy of Bregoli Himself
263917-0
Stellar IC, i wish you the best of luck!
Offline Kokaloo
  • 🤘(• ω •)🤙
Offline JucheCatgirlTS
Absolutely legendary, I may have to pick up a minivan just for this
Sent from my HD1907 using Tapatalk
Offline zoo
    • zoo
interesting mounting implementation. i think you've sold me on plocky. plocky is the way
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
Big thanks to everyone who commented and filled out the IC today! I'm glad people seem interested in my design.   40 responses in about 30 hours.
couldn't have asked for a better Day 1 of IC   :thumb:
Offline yh
  • hyurinkb
I am very glad poo came before pee. This might be my first 40%.
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
For people who saw the bounce and thought 'thats too much bounce'
under the guidance of da 40's bois, I added some gasket tabs to the center of the base and the center of the PCB
(the PCB ones are half height pads to compensate for the added 2mm distance needed to reach the bottom of the flex well.)
263982-0
This reduces the flex by a good amount, I am also working with Esca to try to implement a plate and confirm compatibility with the getawayvan PCB.
link to imgur album with flex video
« Last Edit: Sun, 07 March 2021, 15:50:20 by Heist Morty »
Offline Tree_
Will this come with a Minivan/Ketch/other PCB or would we need to source that ourselves?
Any info on price or colour options?
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
the current plan is no on PCBs but I have launched a second IC form to determine what percentage of people need a PCB, as well as other questions, so I am certainly open to it.
Prices are looking to be pretty accurate, I will release final pricing for the POM/brass units closer to when I plan to begin the GB.
Max units for R3 (excluding FE) is 100, if more than 50 people actually want this board
« Last Edit: Thu, 27 May 2021, 21:34:59 by Heist Morty »
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
Re: [IC] PooPooPeePee Keyboard Carnival Round Three (updated march 8th 2021)
« Reply #17 on: Fri, 12 March 2021, 18:01:53 »
Alright folks, apologies to those waiting for the POM and brass units, but due to my transition to a new manufacturer, I found it prudent to run another round of prototypes. these prototypes are the founders edition, once the founders edition is complete, and people are satisfied with the quality of the boards. I will progress to running the POM and brass units. This will most likely be in 2 months time, thank you for your patience, the PooPooPeePee Keyboard Carnival will come to a town near you soon.
Offline paperassgasket
« Reply #18 on: Fri, 09 April 2021, 23:24:46 »
Offline HappyB0T
  • I'm a Piggie
« Reply #19 on: Mon, 19 April 2021, 21:47:08 »
I have a need to poopoopeepee - GLWIC
Re: [IC] PooPooPeePee Keyboard Carnival Round Three (UPDATED 5/28/21)
« Reply #20 on: Fri, 28 May 2021, 12:43:45 »
Happy to see updates and progress on this man!
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #21 on: Fri, 28 May 2021, 13:09:02 »
Thanks for all the support! I'm not super active on Geekhack but I'll try to stay more on top of the comments on this post from now on.  :thumb:
Offline Cowmovie4
  • hollow keyboard haver
« Reply #22 on: Fri, 28 May 2021, 13:59:21 »
extremely cool, might have me considering trying to squeeze Handarbeit on there :0
u/TheFourthCow - formerly TheFourthCow on geekhack... until I locked myself out.
Designer of the Funky40 - IC TBD
Working on a new board! IC inbound?
https://i.imgur.com/5GVY8I5.jpg
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #23 on: Mon, 31 May 2021, 12:05:29 »
Should have picked up Hand Work instead.  ;D
Offline treeleaf64
    • treeleaf64
« Reply #24 on: Mon, 31 May 2021, 12:57:08 »
Hmm poopoopeepee hm hm
Everyone must pay the cat tax
Offline charlie2407
« Reply #25 on: Mon, 31 May 2021, 13:17:02 »
nice
« Reply #26 on: Mon, 31 May 2021, 18:09:10 »
nice
Offline Chippy
  • sus chef
« Reply #27 on: Mon, 31 May 2021, 19:28:24 »
I love that fillet change, good job.  :blank:
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
Re: [IC] PooPooPeePee Keyboard Carnival Round Three (UPDATED 7/18/21)
« Reply #28 on: Sun, 18 July 2021, 09:47:12 »
UPDATE:
As of today, 7/18/21, the Fe units have shipped to me, once I have received them, and shipped them out, extras will be available, and shortly after that, the group buy will begin. thanks for sticking around for so long folks, we're getting close!
Offline HappyB0T
  • I'm a Piggie
« Reply #29 on: Mon, 19 July 2021, 22:54:53 »
Heck Yes!
Offline conternecticus
« Reply #30 on: Sun, 01 August 2021, 09:28:24 »
Looking forward to the GB!
Offline Jefff
    • jlabs.co
We need this
Offline Friendship
We need this
scroll up my dude, and it shall appear
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #33 on: Tue, 31 August 2021, 19:40:24 »
Alright folks, I did the math, theres no reason to wait any longer, the Group buy for P4kcr3 is going live right now! from september 1st, to september 30th, Poo Poo Pee Pee Keyboard Carnival Round three will be available for Group buy in white or black POM tops with brass bottoms. for $235 shipped CONUS.
https://mascisdesigns.bigcartel.com/
Cases and PCBs should both take around 2 months to complete production, then roughtly another 2-3 weeks of shipping to me/QC.
so group buy should deliver around Christmas if everything goes smoothly.
« Last Edit: Tue, 14 September 2021, 22:01:35 by Heist Morty »
Offline HappyB0T
  • I'm a Piggie
« Reply #34 on: Tue, 31 August 2021, 20:53:36 »
Form filled - Carnival Ready.
Offline whirlwind
« Reply #35 on: Wed, 01 September 2021, 03:01:13 »
Form filled, super excited for my poopoo peepee!
Offline Rico
« Reply #36 on: Wed, 01 September 2021, 14:35:07 »
I just pulled the trigger for case and PCB ;)
Now I need to learn how to type numbers with such a small layout :D
« Reply #37 on: Wed, 01 September 2021, 21:21:55 »
Offline LordHaveMercy
« Reply #38 on: Mon, 06 September 2021, 03:10:22 »
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #39 on: Tue, 14 September 2021, 21:59:21 »
Not worth the time and pain I'd spend making the GH post for the 2 entrants I'd get out of it.
most of this thread is 40's people boosting my post honestly.
« Last Edit: Tue, 14 September 2021, 22:02:28 by Heist Morty »
