Author Topic: [IC] ePBT Creative Studio - [2024-05-14] Now on sale  (Read 216772 times)
Offline jagger27
  • ne 1.5U supers???
Re: [IC] ePBT Creative Studio - [2021-09-20] Kitting Mega-Update!
« Reply #200 on: Wed, 22 September 2021, 11:08:56 »
nice updates!
Offline kapowaz
    • kapowaz industries
« Reply #201 on: Wed, 22 September 2021, 11:46:42 »
Great looking set. I love the addition of the Italian/Spanish/Portuguese kit. I just miss the R3 `^[ for perfect ISO-ES compatibility. Also R2 ´¨ with tertiary legends would be ´¨{ in ISO-ES.
Hi, thanks! Both of these keys are covered in the IT/ES/PT set, but you could be forgiven for not spotting them immediately. In both cases these are ‘dead keys’ (so they are followed up with a compatible character to apply a diacritical mark to), and I have chosen to indicate these with a dotted circle below the corresponding diacritical. You can find the specific keys you mentioned at R3, 3rd from right, and R2, 4th from right.
Offline ideus
  • Björkö.
« Reply #202 on: Wed, 22 September 2021, 16:56:10 »
I saw the legend treatment that you applied to dead keys and found it very interesting, would be a first for legends and would make this set a very special one.
Offline Nascent
« Reply #203 on: Thu, 23 September 2021, 01:36:38 »
The dotted circles threw me off. Great to know. Must buy!
Offline aperumdesign
« Reply #204 on: Fri, 24 September 2021, 02:57:35 »
Can't believe I hadn't seen this until now. What a great idea and set! Definitely in for a whole bunch of kits and deskmat, and really looking forward to hearing about future collaborations
Offline touch
« Reply #205 on: Sat, 02 October 2021, 18:36:02 »
Hoping that 1.25u spacebars can be included... (for those who do split spacebar)
PS Two 2.5u/3u spacebars would also be awesome!
« Last Edit: Sat, 02 October 2021, 20:55:28 by touch »
Offline konstantin
  • Formerly constexpr
« Reply #206 on: Sun, 03 October 2021, 01:21:56 »
That's not a size that exists
Offline touch
« Reply #207 on: Sun, 03 October 2021, 06:16:16 »
ooops no 2.5u then, but 3u does exist right?
Offline saltimate
« Reply #208 on: Sun, 03 October 2021, 06:39:55 »
maybe you were thinking of 2.25 or 2.75? both of which exist
3u does also exist
Offline touch
« Reply #209 on: Sun, 03 October 2021, 18:07:09 »
3u does also exist
Yes, I know they're in the set. It's the reason I'm requesting a 1.25u sb, which is sandwiched in the middle in my case and harder to come by...
Also requesting the 2.5us (yes, I know now that it isn't a thing) and 3us cuz I know they could be a source of derangement for some of us.
« Last Edit: Sun, 03 October 2021, 18:15:20 by touch »
Offline AshF
« Reply #210 on: Mon, 04 October 2021, 01:42:23 »
This is soo good
Sent from my ASUS_I003D using Tapatalk
Offline honpache
« Reply #211 on: Mon, 18 October 2021, 12:03:04 »
Loving this set!
I just noticed this and wanted to make you know just in case
(there's an error in the numpad kits)
277469-0
Offline kapowaz
« Reply #212 on: Mon, 18 October 2021, 12:09:46 »
Loving this set!
Thanks for pointing that out — that is indeed a fencepost error on the row numbers! I’ll be sure to correct the diagrams.
Offline ideus
  • Björkö.
« Reply #213 on: Sat, 06 November 2021, 21:35:25 »
Would the GB for the set run this year?
Offline kapowaz
« Reply #214 on: Sun, 07 November 2021, 02:49:48 »
I had hoped to run the group buy this year, and had started getting other things in place to support that, but at this point I’m not optimistic. I want to get product samples before I run the group buy and I’m still waiting on those. I’m told I should get them within a couple of weeks, but other group buys from ePBT that finished months ago still don’t have samples, so I’ll not hold my breath.
Since there are question marks over colour matching I want to be sure of what the finished product will look like before I commit to a GB; I’d hate for there to be either a protracted waiting period for colour matching (like Dracula) or a massive mismatch between expectations and reality (as with some other reverse dyesub sets).
You never know though; if everything comes together and samples happen quickly it might be possible before the end of the year, but I’d say I’m targeting Q1 2022 at this point.
Offline ideus
  • Björkö.
« Reply #215 on: Sun, 07 November 2021, 08:56:03 »
I concur: A good product later is far better than a bad one soon. Please keep us posted, considering the thread visits this set has a good demand; therefore, there should be many like me, that are waiting for a GB date.
Offline windlabs
« Reply #216 on: Sun, 07 November 2021, 21:01:00 »
nice work
Offline aicyborg
« Reply #217 on: Sat, 20 November 2021, 09:07:50 »
Been thinking about this a ton since I discovered it a while ago and decided I'm really into this. In for neutral alphas & mods, likely modern, possibly nomad.
Apple's insistence to still (even on the 2021 MacBooks, bah) use a non-standard layout in the UK drives me nuts but after so many years of use it's starting to feel a little more natural to me than the "correct" UK-ISO. The idea of having a custom board match my various Macs is really resonating with me. I'm not even a big Adobe user, I just love this project for that reason.
I hope you're able to secure a UK vendor.
Offline kapowaz
« Reply #218 on: Sat, 20 November 2021, 09:10:45 »
Funnily enough I’m in exactly the same boat, which often means I’m missing the exact keys I need for non-uniform profiles. Fixing this in my own set was an important criteria for me, as is having a UK vendor!
Offline loddee
« Reply #219 on: Wed, 05 January 2022, 07:18:21 »
Any updates? :)
Offline kapowaz
« Reply #220 on: Wed, 05 January 2022, 07:21:16 »
Any updates? :)
I'm waiting on production samples from EnjoyPBT. I'm guessing they may not surface before CNY puts everything on hold for a while, though.
Offline Hmarxis
« Reply #221 on: Tue, 08 February 2022, 01:03:42 »
Uuhhhh this is exactly what i have been waiting for!! My god what a delicious set, think ill go all out and buy 3xmodfiers this time.
Offline senencito
« Reply #222 on: Sun, 13 February 2022, 11:21:31 »
Waiting patiently for this. It seems like a great set.
Offline kapowaz
« Reply #223 on: Wed, 16 February 2022, 05:07:51 »
I appreciate yours (and everyone else’s!) patience. I’m still waiting for news on samples — EnjoyPBT have managed to produce samples for a number of other reverse dyesub sets that are in the works, but unfortunately since the queue is largely dictated by which sets already went to group buy, this set is penalised relative to sets which ran their group buy without samples in-hand. It’s very important to me that the set his a high quality bar for the colours though, so I’m not willing to run a group buy before I sign off on samples. Hopefully this means time period from group buy to shipment is shorter though!
Offline kapowaz
« Reply #224 on: Wed, 16 February 2022, 05:11:15 »
I’ve not been checking Geekhack a lot lately, which means I may not see questions or feedback about this set in a timely fashion. I have however recently relaunched my website where I’ll be posting previews of this and other future concepts.
In addition to my website, I’ve also created a new Discord server. This will be the best place to hang out to get timely updates on this interest check and (assuming it gets there!) the group buy.
Offline tof31200
« Reply #225 on: Sat, 19 February 2022, 06:24:54 »
Really nice kit. I'm interested by the french kit (base + PS modifiers + french) but I can't find it in the interest forms
Offline kapowaz
« Reply #226 on: Sat, 19 February 2022, 07:50:02 »
Yes, apologies; I didn’t update the IC form based on the updated kitting, but thankfully the nature of epbt means that there’s no MOQ on child kits provided the main kit hits MOQ itself. So I’m pretty confident all the international kits will be made.
Offline sefixmm
« Reply #227 on: Sat, 26 March 2022, 08:15:42 »
Same, I'm interested in Neutral Modifiers + Neutral Numpad + French/Belgian-French
Very beautiful set :thumb:
Offline niakulah
« Reply #228 on: Tue, 31 May 2022, 00:04:32 »
Any chance this will hop on to the newer and hopefully faster PBTFans queue?
Offline kapowaz
« Reply #229 on: Tue, 31 May 2022, 01:19:45 »
No; PBTFans is doubleshot, so it’s not a suitable candidate to manufacture this set.
Offline kapowaz
« Reply #230 on: Tue, 31 May 2022, 10:19:09 »
I have samples in-hand:
Offline ideus
  • Björkö.
« Reply #231 on: Tue, 31 May 2022, 10:39:52 »
The samples look good. Is there a ePBT's BAE mold available?
Offline kapowaz
« Reply #232 on: Tue, 31 May 2022, 11:22:34 »
Forgive my ignorance but I’m not sure what that is!
Offline kapowaz
Re: [IC] ePBT Creative Studio - [2022-05-31] First Samples
« Reply #233 on: Tue, 31 May 2022, 12:49:38 »
Ahh, Big Ass Enter? If so, no; I don’t think so.
Offline ideus
  • Björkö.
« Reply #234 on: Tue, 31 May 2022, 16:42:50 »
Yes, that is it. I am sorry for the acronym, it is supposed to be "universal" within the MK community; but, I can see that it is not.
Offline kapowaz
« Reply #235 on: Tue, 31 May 2022, 16:48:51 »
No worries; I’d heard of Big Ass Enter but for some reason I was drawing a blank!
Offline ideus
  • Björkö.
« Reply #236 on: Tue, 31 May 2022, 18:24:24 »
Oh, well, that happens. Hehe.
Offline kiwoli
« Reply #237 on: Tue, 31 May 2022, 19:00:28 »
Will you be asking for more samples, especially for the alphas? They look more bluish-grey than neutral grey (they should match to 425C? basing all this on one photo, please excuse if they do look correct in-person) Available mods and accents look well matched.
Personally would hesitate about epbt GBs at the moment, hopefully it's all sorted out by the time this is ready for a GB.
*Look forward to an inDesign add-on kit in the future :thumb:
Offline kapowaz
« Reply #238 on: Wed, 01 June 2022, 00:36:47 »
You’re not wrong that it does look slightly blueish, both in the photo and in person, when compared with the Pantone colour chosen; I would say however that in person the colour cast is incredibly subtle, and most people probably wouldn’t notice. I have requested another round of samples nonetheless since the sub legends aren’t the correct shade of grey either.
Offline DirtyGingy
« Reply #239 on: Wed, 01 June 2022, 01:08:50 »
premiere pro getting no love
Offline kapowaz
« Reply #240 on: Wed, 01 June 2022, 01:17:20 »
I just wanted to quickly touch on this topic; EnjoyPBT has started to work through the backlog of sets and I’m much more confident in their ability to ship now that they’ve worked through the issues with their mould, and so I’m confident in a decent turnaround time for a GB once it’s run (certainly faster than some other manufacturers).
Offline kapowaz
« Reply #241 on: Wed, 01 June 2022, 02:17:23 »
Lots of people have asked for After Effects and Premiere-themed keys, enough that I’ll almost certainly want to revisit those for an R2.
Offline WaynaPawiasek
« Reply #242 on: Wed, 01 June 2022, 12:05:49 »
i will def buy this,
would love to see an InDesign version of this as well. I'd also consider Indesign fitting as it is primarily used for text based products (magazines & books)! :)
Offline Chez
« Reply #243 on: Sun, 03 July 2022, 22:35:12 »
Will almost certainly be buying this.. there are very few sets that offer Icelandic legends, let alone that look good as well!
Offline niakulah
« Reply #244 on: Tue, 05 July 2022, 00:27:34 »
My wallet is ready. Let's go!
Offline Demetri25
« Reply #245 on: Sun, 17 July 2022, 00:01:46 »
Samples look awesome, can't wait to see more  :)
Offline aicyborg
« Reply #246 on: Mon, 01 August 2022, 20:02:55 »
I was just idly thinking about this (left replies before; am definitely on board for base and at least three further kits).
Do you still think you're on track for a 2022 GB?
Offline kapowaz
« Reply #247 on: Tue, 02 August 2022, 02:55:10 »
I had hoped to have been running the GB right now actually, but it was a little optimistic from a production capacity POV with EnjoyPBT. I don't want to suggest any firm dates, but right now it's looking like the tail end of the year. I'm hoping that doesn't mean 2023 though, and I'll be pushing for a date this year!
Offline Lhiebig
« Reply #248 on: Sun, 18 September 2022, 16:54:14 »
I keep tracking this IC. I will definitly buy this. You offer a very nice ISO-FR option i'm looking for. I stay tuned  :thumb:
Offline momoda
« Reply #249 on: Wed, 09 November 2022, 14:31:53 »
can you add base  with brown color?????????   That will be very kind of you.
