Author Topic: [GB] BINEPAD BNR1 - Rotary Encoder | GB ENDED  (Read 20489 times)
Offline binepad
« on: Thu, 11 March 2021, 14:23:07 »
BNR1
1 KNOB MULTIPLE JOB
BNR1 is an CNC machined rotary encoder knob from a solid rod of aluminium.
It can be configured via QMK flashable Atmega32U4 to do just about anything you want it for. It uses EC11 encoder with no detent that means it is smooth when you rotate the knob.
It takes both rotary and click input.
GROUP BUY : 14th March - 29th March 2021
VENDORS
US- Dangkeebs - $55
CA- Keyspresso - $55
EU- Candykeys - €63
ALL OTHER REGION: Binepad - $55
Estimated shipping MAY-JUNE 2021
RENDERS
DIMENSIONS
PROTOTYPE
Programing with VIAL Conf.
FEATURES
•   TYPE C PORT
•   Programmable by VIAL QMK configurator
•   2-Piece Machined Aluminum-6061
Available in two color:
•   WHITE (Top/Bottom)
•   BLACK (Top/Bottom)
BNR1 SHIPS WITH
•    1 x Top CNC Machined Aluminium Knob
•    1 x Bottom CNC Machined Aluminium Frame
•    1 x PCB with TYPE-C Port (Designed by Team Mechlovin')
•    4 x Rubber Feet
•    1 x Rotary Encoder EC11
•    3 x M3 Screw
•    1 x M3 Set Screw
•    1 x 4MM Acrylic Plate
•    1 x Reset Pin
•    1 x L-Key
(Pre Assembled)
GEEKHACK IC
Contact
Discord:binepad#6855
Email:service@binepad.com
Please leave your feedback below
Thank You so much for your support :)
Here is the update:-
• CNC Machining has been completed and sent for painting
• PCB has been Ordered from vendor.
• Packaging has been ordered.
• Once we receive everything assembly will start.
Estimated delivery to vendors will start from 15th May, 2021 7th JUNE, 2021 (Due to lockdown in India)
Images from production
« Last Edit: Sat, 11 September 2021, 12:47:09 by binepad »
Re: [GB] BINEPAD BNR1 - Rotary Encoder
« Reply #1 on: Sun, 14 March 2021, 11:45:33 »
Approved :thumb:
Offline InvXXVII
« Reply #2 on: Sun, 14 March 2021, 12:43:32 »
Been waiting for the GB to go live since yesterday night. Grabbed two the second it went in stock :thumb:
Offline GKboki
« Reply #3 on: Sun, 14 March 2021, 15:13:00 »
Will the surface treatment be improved for gb units? I can see a lot of paint bubbles.
Offline powwu
    • Discord
« Reply #4 on: Sun, 14 March 2021, 15:36:44 »
so lit
Offline binepad
« Reply #5 on: Sun, 14 March 2021, 16:05:48 »
This is just a prototype. Final product will be much better.
Offline Lyle88
« Reply #6 on: Mon, 15 March 2021, 02:02:09 »
Apologies if this is a stupid question, but will this work with a cable that is USB PD capable? If I remember correctly, some usb-C devices have issues with PD compatible cables. Also, do you have any idea if another rotary knob would fit on this? - like a Rama knob for example.
Sent from my SM-G970F using Tapatalk
Offline KaosJ
« Reply #7 on: Mon, 15 March 2021, 05:02:54 »
Entered thanks  :thumb:
By any chance, could you sell extra PCBs too?
Offline Vibex
  • Love y'all
« Reply #8 on: Mon, 15 March 2021, 09:18:57 »
Just ordered mine yesterday!
Offline Skaazi
« Reply #9 on: Mon, 15 March 2021, 15:42:36 »
Looks really nice. Any info on how much it weighs? What kind of finish is going to be used?
Offline Hyde
  • White Tofu Extraordinaire
« Reply #10 on: Mon, 15 March 2021, 16:25:13 »
Sorry stupid question, will this work for Mac? My wife uses Mac.
Offline ChitownM2
« Reply #11 on: Mon, 15 March 2021, 21:50:45 »
Got my order in.
Offline modern
« Reply #12 on: Wed, 17 March 2021, 06:27:00 »
love the look of this
Offline adsfqwer
« Reply #13 on: Sun, 21 March 2021, 02:47:46 »
Very cool. Got it.
Offline Sandersoni
    • andidas.com
« Reply #14 on: Sun, 21 March 2021, 10:58:03 »
Love this. Ordered.
Offline 24kpurehandsome
« Reply #15 on: Sun, 21 March 2021, 19:37:33 »
Love the encoder! But my only issue is that I ran out of ports on my laptop. You think there would be a Bluetooth version of this in the future?
Offline Mark The Weeb
« Reply #16 on: Sun, 21 March 2021, 21:34:03 »
love the vintage volume knob look of this
Offline azzipa
« Reply #17 on: Sat, 27 March 2021, 14:16:26 »
Rotary and clicky input, programmable by VIAL. Anyone know for sure if it’s possible to program layers using tap dance? Seems likely since QMK is underlying, just looking for confirmation.
looks like the answer is: yes, tapdance and/or layers are programmable
« Last Edit: Sat, 01 May 2021, 11:31:47 by azzipa »
Offline binepad
Re: [GB] BINEPAD BNR1 - Rotary Encoder | SHIPPED
« Reply #18 on: Wed, 16 June 2021, 10:03:31 »
BNR1 UPDATE (16th June,2021)
We have shipped BNR1 to all of our vendors and orders received at our platform.
We have received few complaints regarding scratches on the knob. The cause of damage was, BNR1 wasn't held too tight inside packaging so that it doesn't move around. We were too late to figure out this issue. All of our products were completely checked and then packed. We will make sure this doesn't happen again.
No need to worry, we are shipping replacements. Only some orders are facing this issue and many of them have received the perfect product.
If you found any issue in your order, just drop a mail at service@binepad.com we will serve at our priority.
Sorry for the inconvenience caused.
Offline catbus
« Reply #19 on: Wed, 01 September 2021, 19:22:15 »
Is there qmk code available for this?
Offline adsfqwer
« Reply #20 on: Wed, 01 September 2021, 20:33:43 »
It is reprogrammable with Vial (see https://www.binepad.com/bnr1-programing-guide). The default programming is volume up/down and mute on press.
Offline catbus
« Reply #21 on: Wed, 01 September 2021, 22:34:21 »
I get that you can use Vial - but that doesn't offer the level of flexibility that qmk does, and that I am looking for. This was advertised as qmk compatible, was hoping there would be a repo to fork.
Offline adsfqwer
« Reply #22 on: Wed, 08 September 2021, 15:07:05 »
I'm trying to use Vial to configure "tap dance" based macros on the BNR1 (i.e. use the button to do multiple things depending on how many times it's pressed). But the tap dance tab is empty on the latest version of Vial. What's gone wrong?
Offline binepad
Re: [GB] BINEPAD BNR1 - Rotary Encoder | GB ENDED
« Reply #23 on: Sun, 12 September 2021, 12:40:48 »
Accepting some of your request for BNR1 QMK code, we have summited codes on GitHub(qmk_firmware) and waiting for approval.
Codes can also be downloaded from this link G Drive
We also have some BNR1 in stock.
Visit binepad.com to grab before it is out of stock.
Offline domoaligato
« Reply #24 on: Mon, 11 October 2021, 19:44:22 »
Please review and fix the issues with your pull request.
https://github.com/qmk/qmk_firmware/pull/14390
Offline domoaligato
« Reply #25 on: Mon, 11 October 2021, 21:17:33 »
edit: see next post
« Last Edit: Thu, 14 October 2021, 19:07:53 by domoaligato »
Offline domoaligato
« Reply #26 on: Tue, 12 October 2021, 10:23:46 »
edit. the PRODUCT_ID in config.h and the via json is correct for the BN003. via is just missing the json for the BNR1. I am not sure why via is defaulting to the BN003 if the product ID is not in the via repo for the BNR1.
Regardless I had to locally fix a quite a few things from the git, to get qmk to compile for this device.
Also, windows 11 borked my driver stack for atmel devices.
« Last Edit: Thu, 14 October 2021, 19:08:18 by domoaligato »
Offline binepad
« Reply #27 on: Sun, 30 January 2022, 14:18:18 »
New features has been added to VIAL.
Updated BNR1 Hex file can be downloaded using this link G Drive
Offline binepad
« Reply #28 on: Thu, 25 August 2022, 14:16:01 »
Should we go for Round 2 GB?
New surface finish(Anodizing and E-Coating) with better pricing.
Offline irithyll
« Reply #29 on: Thu, 25 August 2022, 14:41:18 »
Yes, please!
« Reply #30 on: Sat, 27 August 2022, 16:14:40 »
In for 2, if this runs again. :)
Offline binepad
« Reply #31 on: Sat, 24 September 2022, 16:07:11 »
BNR1 Round 2 GB is LIVE
New surface finish (Anodizing, E-Coating and Brass Variant) with better pricing.
GB POST
