Author Topic: [IC] Orthograph - 75% split keeb with hot-swap sockets & RGB  (Read 15005 times)
Offline vladkvit
« on: Sat, 13 March 2021, 13:11:29 »
This keyboard was designed to maintain a familiar layout, while being a split ortho keyboard - something that I haven’t seen on the market.
It features a slim height of just 11.5mm, per-key RGB lighting, hot-swap switches, and a bezel-less look on the outer edges.
I’ve been daily driving the prototype for a couple of months, and I think it is pretty darn close to my own personal endgame keyboard.
Layout:
36 keys left half, 46 keys right, for 82 keys total. It was designed to be familiar, while maximizing compatibility with existing keycap sets.
Needs an ergodox set (for the 1.5U keys on the sides & thumb keys) plus one of 75% / 1800 / etc.
http://www.keyboard-layout-editor.com/#/gists/42d33c206b55fc8938cc24da61229e0a
Why split keyboard?
Comfort and posture. With a split keyboard, the shoulders don’t have to be rounded, and easier to “sit up straight”.
How does this differ from Ergodox?
A standard, familiar key layout. Transitioning back and forth from a regular layout doesn’t take long
Slimmer, coming in at 11.5mm, compared to Ergodox’s 19mm
Metal case
Hot-swap sockets
Dual microcontrollers. This speeds up matrix polling, making this keyboard better for gaming
There is individual RGB lighting for every single key
Ortho - makes gaming with WASD more comfortable
Kit contents / What’s included?
Two assembled PCBs, two metal plates, four metal spacers, two base plates, screws, and silicone feet.
It does not include two microcontrollers (preferably Elite-C), switches, or keycaps. The case can be either aluminum or steel.
You need to supply your own split cable and two microcontrollers.
Usability
Here’s a typing demo -
The prototype build doesn’t have lubed stabilizers, stab dampening, etc.
With the current setup, the keyboard feels fairly rigid - there’s no flex. If there’s interest, the spacer plates can be optionally modified to reduce rigidity.
Weight
Fully assembled, with switches and SA keycaps, the aluminum version is 460g (16oz) for the left side and 487g (17oz) for the right side. The total is just shy of 1kg (2.2lbs).
With steel, those weights would be around 1kg (2.2lbs) for the left side and a bit more for the right side - 2kg total (4.4lbs).
Pricing estimated at $290, very roughly. Depends on interest, extra features, and further communication with vendors.
PCB comes with all the diodes, LEDs, and hot-swap sockets pre-soldered. Requires an Elite-C or another thin (<3.6mm) flat-mounted microcontroller.
Additional Potential Features
The current prototype is made from anodized brushed aluminum sheets. There’s an option to get different colors or to get steel.
Switching from Elite-C microcontrollers to built-in electronics. This could take quite a bit of time, and it only really makes sense if there’s strong interest.
Removing RGB. This is fairly straight-forward, and would reduce cost.
Adding a rotary encoder between backspace and F12. This would take a bit of time and testing.
Damping. To dampen the keyboard, the mid-layer sheets could be swapped for a more flexible material. Requires quite a bit more time & research, the keyboard feel is not guaranteed. I could also leave a bit more material out of the mid-layers.
Status
The first prototype works well. I got preliminary pricing from suppliers. Still need to figure out shipping, QC, assembly, and other design tweaks. Currently looking for feedback.
More images
Interest check form. There are questions about customizations, features, and pricing. I would really appreciate any feedback.
https://forms.gle/fVj7hCMCCr5nhy1G7
« Last Edit: Sat, 13 March 2021, 13:50:45 by vladkvit »
Offline vladkvit
Re: Orthograph - 75% split ortho keeb with hot-swap sockets & RGB
« Reply #1 on: Sat, 13 March 2021, 13:13:27 »
Update March 17 2021
Good news - there was enough interest in the keyboard for me to organize a group buy in the future.
There was some discussion on reddit, too - https://www.reddit.com/r/ErgoMechKeyboards/comments/m4fu9i/been_working_on_this_one_for_a_while/
There were several requests to have this board be open source. As an initial step in this direction, here are the interim PCB files - https://github.com/vladkvit/orthograph_keyboard. At the end of the group buy, all of the final design files needed to edit and manufacture the keyboard will be uploaded.
Changes from the prototype.
There was significant interest in damping, so I’ll try to see what I can do there. Will definitely need some time to experiment.
Pretty much everyone wants a rotary encoder, so that needs to be built.
Other things. Color is unlikely to happen due to the small volume of this project (but I’ll check anyways). Just an assembled PCB (no case) will likely be an option.
Update May 1 2021
Some quick notes on the progress.
I got some quotes for foam inserts from a couple of manufacturers. I'm still figuring out the different types of foams and rubbers, and their potential effects on dampening. Also trying to make sure that the dampening doesn't cost an arm and a leg.
I also got a pair of nice!nano board to play around with. They would offer wireless capability and a high matrix scan rate.
Aside - here's a photo of the /dev/tty keycap set on the prototype.
Update June 13 2021
I just got the RGB software working. It needed some QMK changes, will be upstreaming the changes. Here's a video:
« Last Edit: Sun, 13 June 2021, 23:41:00 by vladkvit »
Offline FishyKeebs
  • hey
[IC] Orthograph - 75% split ortho keeb with hot-swap sockets & RGB
« Reply #2 on: Sat, 13 March 2021, 13:24:06 »
Interesting looking forward to seeing how it goes
Offline Tyqar
    • na
Re: [IC] Orthograph - 75% split keeb with hot-swap sockets & RGB
« Reply #3 on: Sat, 13 March 2021, 20:17:15 »
I think this looks like my endgame keyboard also. Gorgeous design.
Sent from my KB2005 using Tapatalk
Offline vladkvit
« Reply #4 on: Sat, 20 March 2021, 12:23:52 »
Posted an update (see above).
TLDR - group buy will happen; need to look into a few modifications.
« Last Edit: Sat, 20 March 2021, 12:26:01 by vladkvit »
Offline vladkvit
« Reply #5 on: Sat, 01 May 2021, 14:14:26 »
Posted an update (see above). Looking into dampening.
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Sat, 01 May 2021, 15:07:38 »
Isn't 290 a lot of money for aluminum sheets    Can you clarify the cost
Everyone must pay the cat tax
Offline vladkvit
« Reply #7 on: Sun, 02 May 2021, 00:30:28 »
There are three things that make up the price - materials, PCB + assembly, and shipping.
The aluminum sheets are less than half of the cost of a keyboard, and there’s more to them than it seems. The two sides of the keyboard are different - there are 12 metal sheets with 6 unique shapes that go into each keyboard. Out of the 6 shapes, 4 have countersunk holes and tapped threads. Each piece is anodized and has a good surface finish. For the order quantity I was targeting (a dozen pieces), the price per piece is fairly high.
For shipping - I first need to ship some components such as microcontrollers and hot-swap sockets to the factories. Then, they send the parts to me (this is surprisingly expensive for metal sheets). Then, I can ship the assembled keyboards to you.
I agree that there’s room for cost optimization. It would require a decent chunk of time - which doesn’t make sense for a small-run project; my current focus is to incorporate popular requests and get it to to people faster. I’m hoping that by having the designs available online, people can have the option of putting it together regardless of the group buy.
« Last Edit: Sun, 02 May 2021, 00:38:35 by vladkvit »
Offline DeMechanica
« Reply #8 on: Tue, 04 May 2021, 10:01:53 »
Love the layout! I’d be keen on a well mounted (top / gasket / leaf spring / etc) high-profile version!
Offline jolly
« Reply #9 on: Tue, 11 October 2022, 00:57:56 »
This looks great, want!
Offline niakulah
« Reply #10 on: Tue, 11 October 2022, 23:13:58 »
I daily drive a Keebio FoldKB which shares a number of similarities with this. Just my 2 cents but I would not go with this because you have a LOT of 1.75U keys which IMO are the worst sounding/feeling keys. They're big enough to sound/feel bad and not big enough to use stabs which would support them and make them sound/feel better.
Offline eigenstasis
« Reply #11 on: Mon, 17 October 2022, 11:16:14 »
looks interesting, what is the current status of this project?
