Author Topic: Spaceshift on Mac?  (Read 6466 times)
Offline pyro
Spaceshift on Mac?
« on: Tue, 16 March 2021, 16:09:12 »
Is it possible to achieve Spaceshift on a Mac? On Windows I use remapkey.exe (from Windows Resource Kit Tools) and Autohotkey (AHK), on Linux xkb/xmodmap, xcape, xbindkeys get you there, but what about Mac? Anybody done this before?
For clarification, by Spaceshift I mean that the spacebar behaves like Shift when pressed and held, but produces a Space character on release if no other button was pressed in between press and release.
Offline nevin
Re: Spaceshift on Mac?
« Reply #1 on: Tue, 16 March 2021, 16:42:44 »
some mac remapping apps:
- KeyRemap4MacBook
- Karabiner
- ControllerMate
whether they do that specific action... i don't know for sure, never looked into that particular action.
Offline Gorbon
« Reply #2 on: Tue, 16 March 2021, 17:53:04 »
Karabiner-Elements can easily do this and much much more. I've been using it extensively for quite some time now.
I wrote you a small config for that. Put it in a .json file under "~/.config/karabiner/assets/complex_modifications/" and then you can enable it in "preferences > complex modifications".
You can adjust the timing parameters to your preferences.
Code: [Select]
  "description": "Spaceshift",
  "manipulators": [
      "type": "basic",
      "from": {
        "key_code": "spacebar",
        "modifiers": {
          "optional": [
            "any"
      "to_if_alone": [
      "to_if_held_down": [
          "key_code": "left_shift"
      "parameters": {
        "basic.to_if_alone_timeout_milliseconds": 200,
        "basic.to_if_held_down_threshold_milliseconds": 200
If you're interested, you'll find lots more in karabiner's documentation.
« Last Edit: Wed, 17 March 2021, 05:51:55 by Gorbon »
Offline pyro
« Reply #3 on: Tue, 16 March 2021, 19:03:23 »
That's great, thank you!
