Author Topic: Have a Cherry Brown.. What's next(/work)?  (Read 2350 times)
Offline worminater
« on: Mon, 16 August 2010, 23:27:30 »
Hola.  So, browsing this forum convinced me to pick up a cherry brown Filco Tenkeyless to replace my aging g15; and I'm hooked.
I am a gamer; and light coder at home(most home coding done on laptop), and I type constantly at work (vim FTW).
The only problem... I'm having with my purchase of this Filco; is I can't stand the membrane i'm using at work anymore.
I love the size/feel of my Filco, but I don't want to just buy a second one without exploring a little.  Should I just make the plunge and pick up a Deck Legend with white's for home, and move my Filco to work; or is their a cheaper alternative which will hold me...?
Suggestions welcome. I don't really have a budget; but I do have a wedding in a few months I'm supposed to be saving for :)
~Chris
Offline clee
« Reply #1 on: Tue, 17 August 2010, 02:55:57 »
Ripster: that is amazing! Never seen it before.
worminator: Just buy one of everything. You'll end up doing it eventually. It's cheap and easy to start with a Model M - you can usually find one on ebay for under $40.
Offline keyboardlover
« Reply #2 on: Tue, 17 August 2010, 07:44:40 »
Key Tronic is a good alternative for work - they're cheap and have rubber domes but very comfortable for typing/coding. Or, if you don't mind a funky layout you could find a cheap used Compaq MX11800 with Cherry browns.
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #3 on: Tue, 17 August 2010, 13:25:54 »
Yea, the keytronic & Compaq are good budget work recommendations.  To me, I use the keyboard at work, even more than home, so I'm not headed for a budget solution and I'll just have to lock it up at night.
Work generally requires more quiet, though so I recommend you take the Filco to work and get something new to try at home if you're looking for more keyboard adventure.  Sounds like you're interested in a tactile backlit gaming board, which really there's only the Déck, unless you're willing to add clicky and try the iOne Xarmour with blue cherries.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline spolia optima
« Reply #4 on: Tue, 17 August 2010, 14:31:30 »
keyboards with PCB mounted MX switches are a tad bit quieter than their metal plate mounted brethren. Have you considered a Cherry-made G80-3000/1800 for work?
keyboards!
Offline washuai
« Reply #5 on: Tue, 17 August 2010, 16:32:34 »
I think it is easier/cheaper to find the Compaq, than to find a G80-1800 in preferred color/key caps/switches, but they would hold one over.
 ✐Intuos or Cintiq
Offline worminater
« Reply #6 on: Tue, 17 August 2010, 20:27:23 »
I have to admit; if money was no object I'd get a hhk without a second thought...
My work environment is pretty "safe"; so I don't worry about leaving a nice keyboard there (I leave an mp3 player+shures on top *too* often over weekends)
I've become partial to the Tenkeyless style I think; I've never really used a numpad so it just gives me a more natural mousing position it seems.
The "Buy one of everything" suggestion scares me; head-fi made a similar remark and I listened too well :(
« Reply #7 on: Tue, 17 August 2010, 20:32:54 »
If money isn't a big deal and you like everything about the Filco but just don't want the same thing you could wait for the Leopold or Ducky tenkeyless (which I believe are forthcoming?) You can check out their separate threads for more info. I think at least one of them will have browns as an option.
Offline worminater
tenkeyless
« Reply #8 on: Wed, 18 August 2010, 08:54:14 »
Both of those (Ducky/Leopolds) look tempting... I'm currently moving my Filco back and forth and that works for now.
Waiting is always the hardest part :)
Offline MissileMike
« Reply #9 on: Wed, 18 August 2010, 09:12:25 »
I solved this very problem by ordering two filco 104 key browns, just waiting on them to show up now :)
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #10 on: Wed, 18 August 2010, 14:46:18 »
Quote from: ripster;213774
Uh, the Ducky and Leopolds have been around for years.   It's always been distribution for anyone outside of Korea/China that's been the problem.
Another classic example: try and buy a Blue Cherry or Clear Cherry G80-3000 from Cherry Corp USA.
Well I was referring to the new Ducky and Leopold models but, fair enough, since it doesn't seem clear how attainable they will be for those outside of Asia.
Offline aegrotatio
« Reply #11 on: Wed, 18 August 2010, 16:10:38 »
Why are the two Windows keys so shiny in that picture?
Did FIlco have to special-order them when the Windows Logo requirements changed to the molded dome key?
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
