Author Topic: [IC] Coding and Simplify Wave Series Deskmats [LAST DAY TO JOIN]  (Read 12331 times)
Offline its.ae
[Coding./] Serie
268409-0268411-1268413-2
02/05 UPDATE
27/04 UPDATE.
Hi everyone!
The samples has arrived and I took a quick pics for you guys. Please beware that the surface is wrinkled, because the sender tried to cram all of the samples into 1 box :(  (So the samples are just for the purpose of showing the color as well as the details, GB product will not have the wrinkled line)
267346-3267348-4267350-5267352-6267354-7
Also these will be the final colorways offered in the GB:
Coding
267356-8
267358-9
267360-10
267362-11
267364-12
267366-13
267368-14
267370-15
Simplify Wave
267372-16
267374-17
267376-18
267378-19
267380-20
267382-21
The GB will be on the 1st of May
Vendors:
EU: Keygem
UK: Prototypist
Canada: Keyspresso
SEA: iLumkb
US: ThockKeys
Thank you guys so much
[/color]
Hi everyone!
I’m currently back form my main job. It has been a long time since my last project and I have learnt a lot from it. Therefore in order to keep up with the demand and also the quality, I decide to run this project as a GB not "in-stock" like before anymore. I’m very grateful to everyone that supported me in the last project!
This time I created 2 separate designs to give you a wider choice depending on your taste: The Coding series and Simplify Wave!
 Coding is a design of mine for my best friend on his birthday. I want this deskmat to express his passion and at the same time be his motivation at work.
And Simplify Wave is a product that I wanted to give a more modern look to the wave pattern while remaining elegant and minimalistic elements.
I hope you can take time and give concurrent opinions as well as recommendations on these two designs. Like last time, I respect and take everyone's opinion serious: https://forms.gle/aLtwDcy36zrsXcKX6
This project will be run in GB format
Specs:
900x400x4mm
Stitched edge
Rubber base
Fabric top
Price: TBD (Most likely the usual price for deskmat)
Time: End of April or May
Vendor:
EU: Keygem
UK: Prototypist
Canada: Keyspresso
SEA: iLumkb
US: ThockKeys
« Last Edit: Sat, 15 May 2021, 13:05:23 by its.ae »
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
Re: [IC] Coding and Simplify Wave Series Deskmats
« Reply #1 on: Sat, 27 March 2021, 05:02:53 »
I really like both, will probably take one of each art!
French keyboard streamer
Offline its.ae
« Reply #2 on: Sat, 27 March 2021, 05:17:03 »
Thank you so much, I appreciate it  ;D
Offline strawberryyogurt
« Reply #3 on: Sat, 27 March 2021, 05:31:32 »
Long time no see Aesthetic!! Still impressive designs as usual!
I have been using your milkyway deskmat and never regret buying it. Should have got the funny looking one too...
Anw I'd love to have the first design in black, the colored code just popped up and catch my attention immediately. The second design looks dope as well but it seem  a little bit too mature for me hahaa
Offline its.ae
« Reply #4 on: Sat, 27 March 2021, 11:37:11 »
Glad that you like it and thank you for supporting me  ^-^
Offline its.ae
« Reply #5 on: Sat, 27 March 2021, 11:39:00 »
Updated US Proxy: ThocKeys
Offline NovaRMK
« Reply #6 on: Sat, 27 March 2021, 12:05:36 »
Yes. Yes, yes yes, yes... yes. Yes.
Offline SDKCAMPING
« Reply #7 on: Sat, 27 March 2021, 14:43:03 »
count me in for a wave mat  :thumb:
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline phuownglinh
« Reply #8 on: Sat, 27 March 2021, 19:56:50 »
woww I have been waiting for these new designs of AE. must say that both of them are really eye-catching for me  :eek: definately gonna take one of the Simplify Wave series.
 Congrats on your new project  :thumb:
Offline its.ae
« Reply #9 on: Sun, 28 March 2021, 10:56:02 »
Your supports mean a lot to me  :thumb:
Offline its.ae
« Reply #10 on: Sun, 28 March 2021, 10:57:11 »
Updated SEA Proxy: iLumkb
Offline Chippy
  • sus chef
« Reply #11 on: Sun, 28 March 2021, 17:25:20 »
these are fun. I like that the center where the keyboard is is mostly blank.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline InverseDC
« Reply #12 on: Sun, 28 March 2021, 18:45:24 »
Nice  :thumb:
Offline ShiroMoria
« Reply #13 on: Tue, 30 March 2021, 01:03:55 »
The wave deskmat is going on my wishlist.
I like that the middle and right side is clear of design and only the left side is covered.
Sent from my SM-G973F using Tapatalk
Offline Necrolegion
« Reply #14 on: Tue, 30 March 2021, 03:20:10 »
Wow! These look really nice!
Offline KKoNaM
« Reply #15 on: Tue, 30 March 2021, 03:29:40 »
iLumb. Very nice
Offline its.ae
« Reply #16 on: Wed, 31 March 2021, 05:05:28 »
iLumb. Very nice
Thank you guys so much. I've read all the recommendation and plan to add
Nice  :thumb:
Thank you guys so much, I've read all the recommendations and planning to add some more colorways and also design elements.
Offline Senbeii
  • Swiggity Swag Whats In Da Bag
    • Keyoto
« Reply #17 on: Wed, 31 March 2021, 14:22:17 »
Really love the designs and colors! As mentioned before as well I find it great that where keyboards are usually placed are blank  :thumb:
Offline its.ae
27/04 UPDATED!
Offline its.ae
Re: [IC] Coding and Simplify Wave Series Deskmats [GB Live Now]
« Reply #19 on: Sun, 02 May 2021, 07:21:38 »
GB Live Now!
Offline its.ae
UK Link Updated
Offline pool
why is there random japanese
why is there random // and }} and function declarations and syntax highlighting and code block ending
 :confused:
Offline its.ae
Numbers updated: (May 7th)
267988-0
Offline its.ae
 :confused:
Sorry if the design does not suit your taste :( I want to create a deskmat that not only express my friend's passion (coding and Japanese) but at the same time can be very friendly and easy recognizable even with people who don't code as well.
