Author Topic: [IC] GMK Pedestrian | Canceled  (Read 30566 times)
Offline paperassgasket
Re: [IC] GMK Pedestrian | Yellow & Black
« Reply #50 on: Sat, 10 April 2021, 01:04:40 »
This is so silly, how could I not?
Plus 40's in base is no joke  ;)
I really like that desaturated Swiss render too. It kinda reminds me of the moon.
Offline Bregoli
« Reply #51 on: Sun, 11 April 2021, 04:11:43 »
Offline nvh2092
Re: [IC] GMK Pedestrian | Watch your Step!
« Reply #52 on: Sun, 11 April 2021, 06:31:45 »
The second set of arrows in base are in alpha intentionally? I feel like an accent version of arrows in base would look better. Also, an accent numpad enter should exist as well in the numpad kit.
« Last Edit: Sun, 11 April 2021, 06:33:37 by nvh2092 »
Offline Bregoli
« Reply #53 on: Mon, 12 April 2021, 01:35:48 »
Numberpad red enter is a mistake, Thanks!
Arrow keys are a personal preference. However I'm not attached to them so if the majority wants me to change it, I will!
Offline Bregoli
Re: [IC] GMK Pedestrian | Kitting update (15/04)
« Reply #54 on: Thu, 15 April 2021, 13:31:48 »
Updates
- Moved End and Pg Dn to Number Pad kit
- Slimmed NorDeUk kit (Removed tertiary legends and added UK ISO to base
- Added red enter key to the number pad
- Renamed Spacebar to Compatibility
- Changed alpha colored arrows to accent color
Offline nvh2092
« Reply #55 on: Thu, 15 April 2021, 15:33:04 »
Updates
Can you consider adding an alpha R3 1u pipe key "\|" to base kit? So you're gonna both have UK and US ISO in base.
Offline Bregoli
« Reply #56 on: Fri, 16 April 2021, 15:22:03 »
Updates
Sorry, I believe you can sub that one key for the ~# key.
I'm trying to keep out lesser used keys!
Offline Bregoli
« Reply #57 on: Tue, 27 April 2021, 13:34:27 »
Can't promise but I'll try to keep it that way :thumb:
Offline Bregoli
Re: [IC] GMK Pedestrian | Deskmats! (2nd May Update)
« Reply #58 on: Sun, 02 May 2021, 13:33:46 »
Here are the proposed deskmat designs:
Offline Sh1zaru
    • Keeb Studio
« Reply #59 on: Mon, 03 May 2021, 03:20:05 »
Set looks great, any possibility to add (optional) email field in IC? This way people can opt in to receive an email when gb is live.
Offline Bregoli
« Reply #60 on: Tue, 04 May 2021, 05:40:19 »
Sorry, I don't feel comfortable collecting other peoples E-Mails. If you would like updates you can join my discord and with the correct roles you can get Pinged for future updates as well as GB Announcements!
Offline Zetina
  • Big bird
    • Instagram
« Reply #61 on: Tue, 04 May 2021, 08:16:40 »
Some of the best novelties I have seen.
Instagram: @zetina.kb
Offline Bregoli
« Reply #62 on: Sat, 08 May 2021, 04:40:05 »
Thanks :D
Offline Bregoli
Re: [IC] GMK Pedestrian | Vendors! (27th May Update)
« Reply #63 on: Thu, 27 May 2021, 07:44:29 »
Vendors Announced
