Author Topic: Switching the Alt and Ctrl keys on Model F?  (Read 1844 times)
Offline Voixdelion
« on: Wed, 18 August 2010, 05:20:15 »
Is it possible to swap the position (function essentially, don't really care about the key itself) of the Ctrl and Alt keys on a Model F AT?
I could get used to the lack of arrows and the backspace mod is definitely in order, but I don't know if I can break the motor habit of the ctrl-v-x-c since I do a LOT of cutting and pasting via the keyboard shortcut.
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline Jack
« Reply #1 on: Wed, 18 August 2010, 05:43:46 »
It's probably easiest to do at the OS. If in Windows you can just use Sharpkeys as it has a feature that will identify the keycode entry when you press the key, makes it easy to remap.
Offline Voixdelion
« Reply #2 on: Wed, 18 August 2010, 06:00:23 »
Quote from: Jack;213848
What is "Sharpkeys''?  In windows or 3rd party software?
Offline hyperlinked
« Reply #3 on: Wed, 18 August 2010, 06:18:21 »
AutoHotKey seems to be the key remapping utility favored by 9 out of 10 GeekHackers who chew PC's.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Jack
« Reply #4 on: Wed, 18 August 2010, 07:00:37 »
Quote from: Voixdelion;213849
Third-party freeware. Basically just a GUI for remapping keys via the registry. AHK is nice but for something so low-level like swapping ctrl and alt I would just use Sharpkeys.
Offline British
« Reply #5 on: Wed, 18 August 2010, 08:47:42 »
Quote from: Jack;213863
Care to elaborate on that ?
Offline Jack
« Reply #6 on: Wed, 18 August 2010, 12:29:06 »
Quote from: British;213876
AHK is an application that sits in the systray capturing keystrokes in realtime and converting them or executing scripts as instructed. Sharpkeys is simply a tool for doing key remaps in the registry that you could do manually if you really wanted to, and when this is done you don't leave any application running; Windows just does a certain keystroke for a certain scan code input as instructed and there's not really any overhead like you would have with using AHK. To put it simply AHK isn't worth using for something so simple, only if you were actually going to script macros with it.
Offline Voixdelion
« Reply #7 on: Wed, 18 August 2010, 15:31:06 »
Quote from: Jack;213982
It can be done manually via registry also?
