Author Topic: [IC] DCS Alps Pingmaster - GB Thread Live  (Read 120580 times)
Offline DetectiveNio
Re: [IC] DCS Alps Pingmaster - GB Starts Monday, August 16
« Reply #100 on: Mon, 16 August 2021, 16:39:56 »
Mechs&Co isn't up yet right?
Offline Fredington
    • Instagram
Offline Define
« Reply #102 on: Mon, 16 August 2021, 20:31:19 »
ETA for DeskHero?
Offline Fredington
    • Instagram
« Reply #103 on: Mon, 16 August 2021, 20:57:51 »
ETA for DeskHero?
Probably sometime tomorrow TBH.
Offline mode
« Reply #104 on: Tue, 17 August 2021, 04:55:55 »
It baffles me that only 2x R3 relegendables are in that kit, so I'd need two of them for a 4x6 macropad.
Nope, I'm out.
« Reply #105 on: Tue, 17 August 2021, 13:29:19 »
Will the fragile stems in the spacebars be an issue since they are ABS?
Offline Fredington
    • Instagram
« Reply #106 on: Tue, 17 August 2021, 15:09:01 »
Unfortunately, this comes with the territory. It's either fragile stems or spacebars that don't fit. I highly recommend being extra cautious when removing the ABS keys. Particularly with the spacebars, I suggest removing the Alt keys on either side of them first, then pulling up on each end evenly and simultaneously. In general however, it's good to be more cautious when removing Alps keycaps, as the stems are inherently less durable than the MX design.
All vendors are now live. GB thread will be up shortly, after which I'll be locking this thread. Please continue any further discussion there.
US: Mechs&Co
CA: Desk[H]ero
UK: Proto[Typist]
EU: MyKeyboard
AS: zFrontier Chinese and English
OC: Daily Clack
« Last Edit: Tue, 17 August 2021, 15:10:43 by Fredington »
Offline mode
« Reply #107 on: Wed, 18 August 2021, 00:28:21 »
ABS fragility comes from doubleshotting, the spacebars are single shot as they're one colour. I wouldnt worry about it.
FWIW, I've mounted an unmounted yuri several times without damaging a keycap, i think this fragility is overblown if you're using them with SKCM switches, I believe matias stems are much tighter so I could well believe they'll break when pulling from matias.
Offline F13
Re: [IC] DCS Alps Pingmaster - Live, GB Thread Pending
« Reply #108 on: Fri, 20 August 2021, 01:45:29 »
It's great to see the GB live...congrats!
I'm also happy to see the changes you made to the legends on the shift keys - it looks so much better without the arrow icon.
Time to start buying...
Offline Fredington
    • Instagram
Re: [IC] DCS Alps Pingmaster - GB Thread Live
« Reply #109 on: Fri, 20 August 2021, 20:40:18 »
