Author Topic: Possible to re-flash keyboard and have it re-programmed?  (Read 1303 times)
Offline Keypadgamer
« on: Wed, 07 April 2021, 10:35:35 »
Hi,
I made a post on here a while back detailing my woes with the '' smartyao lm-92'' AKA ''Koolertron 48 key gaming keypad''
In a nutshell the keyboard has an inherrent fault where sometimes when trying to hold a key and then press another (for example, shift + a letter) it would occasionally not register you are holding the first key down until you release it and press it again.
From my experiences since making it im 100% certain that theres something faulty going on with how its been coded/programmed. The hardware on both of these boards i own is ostensibly fine.
I wondered if it were possible to pay someone to re-do the programming side of things and in doing so un-botch the problem that has plagued me for so long.
Alternatively i have looked into buying different boards but theres hardly anything else like it on the market, if anyone could recommend me something of a similar layout id be interested.
