Author Topic: [FEEDBACK3] base/hirigana set  (Read 3243 times)
Offline moistcorn
« on: Thu, 08 April 2021, 01:40:21 »
Updated changes:
Adjusted arrows from previous feedback discussion
Toned colors on modifiers
set with font style for the most part, small changes will be implemented if needed.
Novelty +additional keys render will be coming soon thanks for patience!  :thumb:
« Last Edit: Thu, 08 April 2021, 08:53:25 by moistcorn »
Offline joecoolbob
Re: [FEEDBACK3] base/hirigana set
« Reply #1 on: Thu, 08 April 2021, 14:47:02 »
From a quick look at your sublegends, there are some that are not in the right place. You might want to make sure they are in the right locations. For example, you have big and small 'お' on the same key. Also just my personal preference but i really do not like the sublegend fonts haha.
268.2 | MEME | Kendo FE
Offline moistcorn
« Reply #2 on: Fri, 09 April 2021, 21:11:03 »
sticking with font but thanks for bringing attention to the other stuff
