Author Topic: [GB] Geekark Slash - GROUPBUY CLOSED  (Read 6190 times)
Offline seh0nk
    • tech advantage blog
« on: Thu, 08 April 2021, 18:36:01 »
Geekark Slash
266196-0
Note: this is posted by seh0nky on behalf of keyboardfishy.
Live Now!Product Page: https://keebsforall.com/products/ic-pbt-slash
Discord for Updates: https://discord.gg/dRjsAh5jMX
Geekark Slash is a bold gradient set by Fishykeebs. It is inspired by a blood moon sunset. The mixture of cool and warm colors brings a dynamic colorway to your desk.
266198-1
Date
April 12th to May 31
Vendors
Worldwide: Keebsforall.com
Pricing and Kitting
266192-2
We chose to go with a single expansive base kit. It will be priced at $80 and made of dye-subbed PBT plastic.
The base kit covers 60 to full size layouts as well as ISO, alice, split spacebar, 1800, and F13.
266428-3
Board Renders
Done by MakerJake.
266194-4
Nemui by Bachoo.
266190-5
Dalco 959 Mini by Hand Engineering.
266196-6
MAJA by KBDFans and Vulcan.
Closing Remarks
Special Thanks To:
Candice from Keebsforall
seh0nky
Acitrin
Simbusped
Aad
Dudeship
I hope you consider our set!
« Last Edit: Fri, 04 June 2021, 11:00:03 by seh0nk »
Offline FishyKeebs
  • hey
Re: [GB] Geekark Slash - April 12th - $80 Base Kit
« Reply #1 on: Mon, 12 April 2021, 19:50:07 »
Reserved
Offline seh0nk
« Reply #2 on: Mon, 12 April 2021, 19:50:15 »
Reserved
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #3 on: Sun, 18 April 2021, 14:17:06 »
Why does this set feel so incredibly rushed? The single kit has numerous problems.
- Terminal ISO >< key doesn't fit with the pattern
- The two B keys are different colours and the Maja render shows that it doesn't work
- Has two 1u Alt keys but doesn't work on HHKB because of the lack of 6u and 2x1.5u Super keys
- Does NOT support 1u Fn
- Does NOT support split Plus
- Does NOT support scooped 5
- Does NOT support split Backspace or white tilde
Furthermore, the Maja render shown at the bottom isn't even a possible configuration. The left Spacebar is 2u, which isn't supported in the set.
Honestly, I think the group buy should be cancelled until some of these basic changes are worked out.
