Author Topic: [IC] SA Avostar  (Read 11248 times)
Offline RivieraS
  • Yutop
[IC] SA Avostar
« on: Sun, 11 April 2021, 12:40:09 »
Hello everyone, welcome to the IC for Domikey SA Avostar.
This is the keycap that belongs to the hot summer of 2021.
Inspired by the avocado ripening in August and September.
The oily yellow of the core, the bright white of the flesh, and the dark green of the peel are the most dazzling colors doubled under direct sunlight.
If all goes well, the season when the avocado is ripe is the season when you receive the keycap.
Renders
        Avostar + MweoTool X1
  • Produced by Domikey
  • SA profile
  • MX-style stem
  • ABS doubleshot legends
Kits
Base
Icon-Y
Plus
Numb
Color
ISO
Icon-G
Space-L
Space-Y
Space-W
GB Plan
TBC
« Last Edit: Mon, 12 April 2021, 06:18:04 by RivieraS »
Offline c0d3r
Re: [IC] Domikey SA Avostar
« Reply #1 on: Sun, 11 April 2021, 13:21:24 »
OP, your keycap set is gorgeous. But its better to ask Domikey (Kprepbulic) to fix its infamous bug before considering to run a GB from them:   the < and > keys were misaligned in all its current SA keycap sets on the market.  I won't be considering to buy any SA keycap sets from them before they fix this bug.
« Last Edit: Sun, 11 April 2021, 14:00:07 by c0d3r »
Offline c0d3r
Re: [IC] SA Avostar
« Reply #2 on: Wed, 14 April 2021, 20:43:53 »
and the picture shows how bad the company is (the ALT key came from Domikey SA BoB/WoB set):
Offline P103
Re: [IC] SA Avostar
« Reply #3 on: Wed, 14 April 2021, 20:49:04 »
That is some barebone base kit.
Offline GLOVE
重新: [IC] 萨阿沃斯塔
« Reply #4 on: Wed, 14 April 2021, 23:04:59 »
BoB/WoB is the first batch of keycaps produced after the establishment of domikey company
Because the early injection molding workers are not skilled in the defects caused by.
Offline RivieraS
  • Yutop
Re: [IC] SA Avostar
« Reply #5 on: Thu, 15 April 2021, 03:57:20 »
Hi bro,we have started sampling and will be able to provide you with photos of the samples soon. We will absolutely avoid such mistakes.
Offline norb
Re: [IC] SA Avostar
« Reply #6 on: Thu, 15 April 2021, 12:52:50 »
also please don't make the same mistake that drop does with every domikey set and add the 1.25u shift in the iso kit.
if you leave it this way, iso boys have to buy the plus kit for one. single. key. and that's bull**** bro.
Offline orangest
Re: [IC] SA Avostar
« Reply #7 on: Thu, 27 May 2021, 14:55:56 »
Nice looking set! Would you mind sharing the name of the font you used for the title?
Offline ocm
  • Formerly OneCreativeMind
Re: [IC] SA Avostar
« Reply #8 on: Thu, 27 May 2021, 15:37:50 »
Mod tilde in "Plus" kit for HHKB pls :)
Offline orangest
Re: [IC] SA Avostar
« Reply #9 on: Thu, 17 June 2021, 18:30:52 »
Does anyone know the font used in the title image?
Offline Baughsach
Re: [IC] SA Avostar
« Reply #10 on: Mon, 19 July 2021, 02:48:12 »
I'd cop for sure, love the color scheme and avocados. what kits would i need to buy for a tofu65?
Offline EdgeOfInfinity
Re: [IC] SA Avostar
« Reply #11 on: Tue, 27 July 2021, 12:50:30 »
yeah much s'alt' with this one  ;)
