Author Topic: Finally got to use my Macally MK-96  (Read 5633 times)
Offline vyshane
« on: Wed, 18 August 2010, 21:25:50 »
Yesterday my iMate ADB to USB adapter got delivered, which means that I finally got to use my Macally MK-96 - a few years after I purchased it. I dig the ALPS switches. I like them better than the buckling spring actually. They are just as noisy though!
However, there are a few issues:
1) Keycap nubs are on the d and k keys instead of f and j. Not a biggie. I swapped the keys around.
2) Placement of ESC is not at top leftmost. I use Vim a lot. This might finally drive me to bind jk to leave insert mode in Vim and bash Vi mode.
3) Non inverted T arrow keys. I can get used to that.
4) Last but not least. This is the big one. I usually bind ctrl to the caps lock key. I proceeded to do that with the MK-96. Pressing the caps lock key activates ctrl as expected. However, I can't do combos with it, e.g. ctrl-a does not work. This is a big downer. I use combos that involve the ctrl key a lot. I use them for switching virtual desktops in OS X, and for window management in Vim and tmux.
Verdict? I don't think I'll use this keyboard much. Some of the issues, I can get around, but not the caps lock - ctrl problem.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Wed, 18 August 2010, 22:37:14 »
I had the same problem with that 'board, but in OS X I rarely use Control anyway.
Offline xsphat
  • Enlightened
« Reply #2 on: Wed, 18 August 2010, 22:38:16 »
Hey Rip, I finally got a Selectric. It's a Selectric 1 with a 15" carriage, 1959, in black. I love it.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #3 on: Wed, 18 August 2010, 22:48:30 »
This may sound really silly and useless but if you really dug the keyboard apart from the control-a issue, how about nixing the capslock traces and doing jumpers to the Ctrl key?
Quote from: xsphat;214231
He nice to see ya =)
I just lost my Selectric I with my Selectric II =(
I am probably the only moron who could loose a mechanical typewriter (let alone two of them)
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline xsphat
  • Enlightened
« Reply #4 on: Wed, 18 August 2010, 22:56:17 »
The site says I last visited in May - top that Welly-Belly!
And congrats on losing 85 pounds of typewriters, lol.
Offline clickclack
« Reply #5 on: Wed, 18 August 2010, 23:11:02 »
To the OP-
The more I think about it, maybe the trace and jumper idea would really be usefull to you. I think I would actually try that if it was an issue I was having.
Quote from: xsphat;214235
CLASSIC!
I needed that =)
Quote from: ripster;214239
  And for fun ...
It's a trap!!!
Offline vyshane
« Reply #6 on: Wed, 18 August 2010, 23:15:09 »
Quote from: clickclack;214234
I pulled the trigger on a SIIG Minitouch (GH Space Saver), which has a sane ESC key placement as well as inverted T arrow keys. I probably won't bother modding the MK-96.
Offline clickclack
« Reply #7 on: Wed, 18 August 2010, 23:26:16 »
Congrats =)
Offline vyshane
« Reply #8 on: Wed, 18 August 2010, 23:39:12 »
Quote from: clickclack;214255
Congrats =)
Thanks :) This comes after a year of not buying any keyboards. I hope that buying that ADB to USB connector does not turn out to be the start of a chain reaction!
Offline iMav
  • geekhack creator/founder
« Reply #9 on: Thu, 19 August 2010, 03:11:30 »
The mk96 are great for the money (can be had NIB relatively cheaply if you keep your eyes peeled on eBay).  I have several of them as they are great give away keyboards (assuming you have some iMates to pass along as well...which I do).
Offline vyshane
« Reply #10 on: Thu, 19 August 2010, 03:23:42 »
Quote from: iMav;214315
Yep, I got mine when you posted about it here. Thanks for the tip!
I bought two of them back then, and gave one to my colleague. I only waited two years before I decided to get an iMate so that I can use it :P
Offline keyboardlover
« Reply #11 on: Thu, 19 August 2010, 08:01:07 »
You can find them NIB on sale for $10 here.
Offline spear
« Reply #12 on: Thu, 19 August 2010, 14:27:08 »
Quote from: vyshane;214215
I remember that when I first got a Mac (clone), people thought this couldn't be done with ADB keyboards because of the way caps lock key up/down events were generated (down event on first key press, up event on second key release).  However, someone eventually figured out a way to do it and created uControl (originally iControl).  (It doesn't work for later versions of OS X.)  I also used to compile my own Linux kernels just to patch it with a version of this method.  I did that until my old Powerbook died.
I'm not sure whether that method would have worked with an ADB-USB adapter, though.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #13 on: Thu, 19 August 2010, 19:32:28 »
I gained about 40lbs of typewriters when I got an old Smith-Corona from about 1940.
Offline vyshane
« Reply #14 on: Mon, 30 August 2010, 20:27:44 »
So I cracked. While waiting for the SIIG Minitouch, I went ahead and did it. Caps Lock is now nixed and Ctrl has taken it's place. Now using this keyboard at work.
Offline clickclack
« Reply #15 on: Tue, 31 August 2010, 02:19:49 »
Many lawls!
You just made my day =)
Wait, scratch that! I have been sick for a few days so you made my week!
haahaa, I really needed that, thanks =)
...and congrats on doing it!
Quote from: vyshane;218398
Offline itlnstln
« Reply #16 on: Tue, 31 August 2010, 07:38:42 »
Quote from: ripster;218423
Hahaha!  HW beats SW any day.
That's why I like DIP switches.
Offline didjamatic
« Reply #17 on: Tue, 31 August 2010, 07:56:50 »
I love crimes of passion against capslock keys.  This mod definitely qualifies.
You could run those wires to a dip switch or jumper block and make the mod reversible via flick of a switch or two.  Not that you would want to reverse it though.
Offline vyshane
« Reply #18 on: Tue, 31 August 2010, 08:03:54 »
Quote from: clickclack;218445
Many lawls!
Thanks for planting the seed. Hope you get well soon :)
Offline vyshane
« Reply #19 on: Tue, 31 August 2010, 08:08:26 »
Quote from: didjamatic;218482
I don't think I'll want to reverse it. I'll cross that bridge if I ever come to it.
The GH Space Saver is getting closer:
  • Out of Foreign Customs, August 31, 2010, 7:51 am, AUSTRALIA
  • Into Foreign Customs, August 31, 2010, 6:27 am, AUSTRALIA
  • Arrived Abroad, August 31, 2010, 6:26 am, AUSTRALIA
Hopefully tomorrow!
