Author Topic: Keycaps compatibility  (Read 2941 times)
Offline williambs
« on: Fri, 23 April 2021, 10:30:36 »
Hello members, i want to know if the keycaps of the second image its compatible on the one (RAZER). I think the ALT/FN/CTRL right it is not, did you agree overall? its not compatible...          267058-0                 267060-1
Offline zslane
Re: Keycaps compatibility
« Reply #1 on: Fri, 23 April 2021, 11:34:46 »
You are correct. The keycaps in the second image are for an all-1.25u bottom row, while the black keyboard has a 1.5-1.0-1.5/1.5-1.0-1.0-1.5 bottom row.
Offline williambs
« Reply #2 on: Fri, 23 April 2021, 12:21:02 »
yeah the measures, its what im looking for, ty ;)
