Author Topic: Seeking docs on interface requirements for Cherry switches  (Read 1607 times)
Offline esr
  • Yes, *that* ESR. It's what they always ask.
    • Home page
« on: Sat, 24 April 2021, 19:57:57 »
Suppose I want to design a switch that  is a drop-in replacement for a Cherry - able to plug into keyboard bases designed to accept them, and able to support a keycap designed for them.
Where are the electrical and mechanical interface requirements for Cherry switches documented?
Unicomp New Model M
Offline MIGHTY CHICKEN
Re: Seeking docs on interface requirements for Cherry switches
« Reply #1 on: Sat, 24 April 2021, 20:43:30 »
https://drive.google.com/file/d/1mCyr-2AKkUAvFVv7urUcg1ZXiUHRZjrM/view
There's this switch datasheet which is commonly referenced for keeb design, hope this helps a lil bit
Offline esr
    • Home page
« Reply #2 on: Sat, 24 April 2021, 21:13:40 »
Thanks, that looks like what I needed.
Has anyone in the modding community gone so far as to make a CAD model from this?
Unicomp New Model M
Offline treeleaf64
    • treeleaf64
« Reply #3 on: Mon, 26 April 2021, 23:27:56 »
Yes probably. The hard part is finding them.
Everyone must pay the cat tax
« Reply #4 on: Tue, 27 April 2021, 06:11:46 »
If by "CAD" you mean PCB symbols and footprints, then yes there are lots of them on Github, especially for the PCB designer KiCAD.
It shouldn't be too hard to find 2D plate designs in .DXF format either.
3D models is a different story.
