Author Topic: BM980RGB BM980 RGB HOT SWAPPABLE PCB PROGRAMMED QMK VIA  (Read 9128 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Tue, 27 April 2021, 03:14:54 »
Spec
1\98 keys(with Numpad Zone)
2\Fully programmable PCB(VIA supported)
3\Full hot-swappable switch sockets
4\Full RGB switches Leds(With kinds of LED effects)
5\MX Stem support
6\All components of the board have been pre-soldered so the PCB is ready for key switches and LEDs
7\Type C port
BUY NOW
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: BM980RGB BM980 RGB HOT SWAPPABLE PCB PROGRAMMED QMK VIA
« Reply #1 on: Tue, 27 April 2021, 03:15:30 »
