Author Topic: Black and white keycaps  (Read 4476 times)
Offline Atomic17
« on: Tue, 27 April 2021, 13:03:46 »
Im looking for some black and white keycaps but cant really find any that i like does anyone have a suggestion?
Offline Sup
Re: Black and white keycaps
« Reply #1 on: Thu, 29 April 2021, 16:34:22 »
black and white as in black on white or white on black?
current
Coming soon
Offline Darthbaggins
  • PC Cannibal
« Reply #2 on: Fri, 30 April 2021, 14:55:15 »
^ this
other than TaiHao has both versions and are kitted for many board layouts (131 key sets).  Just depends what you want and how far into your pocket you want to spend on said caps.
« Reply #3 on: Sun, 30 May 2021, 17:20:00 »
Black on white or white on black?
https://drop.com/buy/tai-hao-cubic-abs-bow-wob-keycap-set?mode=guest_open
These are great - just wait for the drop to happen again.  I bought a set of each so I can mix and match.
Offline MIGHTY CHICKEN
« Reply #4 on: Sun, 30 May 2021, 18:00:34 »
Check out geekark bow and geekark wob
