Author Topic: Help me find a PCB compatible with Tada68 Aluminum case  (Read 4498 times)
Offline lakiozoon
« on: Sat, 01 May 2021, 08:56:29 »
I managed to screw up my Tada68 pcb, and now am looking for a new one.
I would prefer it being hotswappable but any other case would do.
As far as I know DZ65 RGB V2 hot swap Pcb isn't compatible with the Tada68 aluminum case (the high profile one).
I can solder the switches, but I would really prefer Pcb having the resistors/diodes and whatnot, pre soldered on the Pcb.
If you know any Pcb that fits please let me know.
Cheers!
Offline Arch4Life
Re: Help me find a PCB compatible with Tada68 Aluminum case
« Reply #1 on: Sat, 01 May 2021, 09:23:25 »
kbd67 v2 could do the trick, also xd68
Sent from my SM-N960U using Tapatalk
Offline lakiozoon
« Reply #2 on: Tue, 11 May 2021, 12:56:37 »
Thanks for the reply!
Would it be possible to use the screw-in stabs on kbd67 rev2 pcb providing I get a different plate? (I only have Tada68 stock steel plate)
If so, any pointers to the plate that would fit screw-in stabs on the kbd67 rev2 pcb and Tada68 alu case?
Or I could just get a file and try to modify the existing plate to fit the stabs.
« Last Edit: Tue, 11 May 2021, 13:01:12 by lakiozoon »
