Author Topic: [IC] Ristretto - A 40% Col-Stagger Keyboard  (Read 6809 times)
Offline fruitykeeb
    • Storefront
« on: Wed, 05 May 2021, 08:43:51 »
Ristretto
by fruitykeeb
Discord
Consider filling out the IC form
https://forms.gle/RpKJoUMydEqEqQE2A
About
Ristretto is an integrated, column stagger 40% keyboard.
It features up to 49 keys, OLED support, optional rotary encoder, and various bottom row layouts to fit every preference.
The Unibody Split design combined with Column Staggered keys results in an ergonomic and natural typing experience.
Kits and Pricing
Please note prices are estimates and are subject to change
FR4 Kit - 60 USD
A base FR4 sandwich kit will be available and includes the following:
- Integrated PCB
- Switch plate and base plate in black or white
- OLED and Encoder
- M2 Standoffs and screws
Gasket Mount Acrylic Case - 75 USD
A premium add-on case designed by Jake at the P3DStore
- 7 Layer Stacked Acrylic design
- Drop in compatible with FR4 kit
- Included feet raise the board to a ~6 degree typing angle
- Dozens of color options including custom engraving
- Laser cut POM and PETG plate options
Pictures
FR4 kit
Photos by me
Acrylic Case
Photos by Jake
Silkscreen and Naming:
Created by the incredible dasherby#7777 <3
A little history behind the name and design choices:
Ristretto is a short shot of espresso, typically just the first half of a normal espresso shot; this gives a sweeter, fruitier, and richer flavor compared to espresso.
Dasherby took this coffee theme and ran with it, creating an adorable friend filled to the brim with that sweet sweet cocaine we call coffee.
Base plates will feature the Ristretto and credits in exposed copper.
Supported Layouts:
Notes about layout:
The bottom layouts are compatible and interchangeable on both left and mirrored on right side.
All leftmost 1u options (below C and <) can be substituted for the 1.25 vertical option; this is visible in the pictures above.
Because of switch placements, the 1-1-1.5 is only supported only on FR4 kit. This is not compatible with the acrylic case.
Vendors (Worldwide):
FR4 Kits: https://fruitykeeb.xyz
Acrylic Cases: https://p3dstore.com
If all goes well, GB should be in a few weeks!
Thank you so much for reading!
Updates:
(2021-5-5) IC posted
Offline Benchiridion
Re: [IC] Ristretto - A 40% Col-Stagger Keyboard
« Reply #1 on: Wed, 05 May 2021, 08:47:15 »
I enjoy this.
Offline FishyKeebs
  • hey
« Reply #2 on: Wed, 05 May 2021, 08:52:22 »
gib
Offline itsazly
    • website place
« Reply #3 on: Wed, 05 May 2021, 09:59:35 »
ye i'm about this and your other projects my dude
Offline taki
« Reply #4 on: Wed, 05 May 2021, 12:00:19 »
i love it and need it now :D
Offline Achromous
  • noesc.co.uk
    • NOESC
« Reply #5 on: Wed, 05 May 2021, 12:32:32 »
Looks good, I'm going to assume the custom engraving options for the Acrylic comes at a cost, any idea on how much that will be?
Also I assume the screws holding the acrylic stack also have various colour options?
Offline PradyXT
« Reply #6 on: Wed, 05 May 2021, 12:33:12 »
This looks amazing and I really want to get this :D
I'm doing a split build soon and this fills up all of the requirements :D
Pricing is subject to changed based off the quotes you receive, right?
Offline fruitykeeb
    • Storefront
« Reply #7 on: Wed, 05 May 2021, 13:13:54 »
Yes, the engraving options will be through P3D and it tends to be +40USD for the engraving.
There are 10 different colors for the case bolts too, color options can be seen here.
Thank you! Yes, pricing will likely change based on the quotes I receive  :D
