Author Topic: Hot-swappable, full ISO keyboard options?  (Read 1693 times)
Offline soeren
« on: Sat, 08 May 2021, 08:24:59 »
I've been using my Filco Majestouch (MX Blue) since 2010, and always liked it although I think its a little loud and ringy. I recently started looking into switches again after trying some tactile ones which I really liked, one thing lead to another, and now I'm halfway down the rabbit hole that is mechanical keyboards again. And sweet jesus a lot of new options have emerged since 2010.
After reading a lot of threads and looking at a bunch of videos, Im leaning towards getting a barebone keyboard and trying out some different tactile switches (especially looking forward to trying Pandas).
Now, what are my options beside the GMMK if I'm looking for a barebone/hot-swappable, full ISO keyboard? Most I've seen are either TKL or smaller, or ANSI only.
« Last Edit: Sat, 08 May 2021, 11:00:49 by soeren »
Offline Faceman76
Re: Hot-swappable, full ISO keyboard options?
« Reply #1 on: Sat, 08 May 2021, 10:02:55 »
Try damping your case and lubing the stabilizers first, it will rattle less.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
