Author Topic: Hello From Austria! (= need advice on my first pcb  (Read 1657 times)
Offline SirMissaot
« on: Mon, 10 May 2021, 06:57:49 »
Hello.
Pretty new to this, im reading into keyboards for the last week and just started with my first pcb:
- Keymatrix is done and i know how to wire it.
- i use the at90usb1286 so its not so easy to find 1-1 tutorial examples.
can someone tell me if my MCU/USB_C Schematic and trace routing between them is ok and good to go?
i simply dont know how to route it without crossing lines/using vias and which USBC-Receptacle to use
Thansk in advance!
